nosecone- wont come off
Post by zabo on Thu Mar 26, 2009 9:22 pm
m trying to remove the nose cone from a 64 swingaxle.
I took all the bolts off and the nosecone will lift about 1/2" but i cant get it all the way off.
wht could it be hanging up on? Is there a trick to this?
Re: nosecone- wont come off
Post by Clyde on Thu Mar 26, 2009 10:52 pm
Did you try shifting? in, out, rotate. Been a while, but it seems like there's a sweet spot that the hockey stick needs to be in, for the cone to come off.
It's been a while, and this is my knee jerk reaction, I may be wrong.
Post by zabo on Fri Mar 27, 2009 6:19 am
i tried rotating the shaft i can get it to turn abt 45 but still no luck-
Post by camch on Fri Mar 27, 2009 6:50 pm
try to pull it out in neutral if that does not work you probally have a bent rod,you can give it a little extra pull just dont use a pry bar
Post by zabo on Sat Mar 28, 2009 10:30 pm
thaanks- got it out- hockey stick was really stuck in the nose cone. gave it a few light taps with a mallet and it came off..
