My 1969 Miss Money Penny
Post by Rwflyboy on Wed Apr 29, 2015 12:02 pm
Odd Beetle.
Trying to find country of origin. Mexico, Canada, Brazil?
A few of the Non USA 1969 model differences
  1. Kmh Speedo
    Swing Axle
    Metal Dash
    No Side trim/chrome
    No defroster in rear window
    Turn signals have split window between front and side light
Rwflyboy
Number of posts : 56
Registration date : 2014-04-13
Re: My 1969 Miss Money Penny
Post by Heinz57 on Thu Apr 30, 2015 8:48 pm
Looking at the pictures, here's what I know. Your car has a full headliner and no dash pad but has the dash trim. European Beetles did not get the dash pads till later in the 1975 time frame. They did build a "Sparkafer" model which was a standard Beetle, basically continued production of the 1967 Swing axle Beetle until 1976. This model can be ID by the center only headliner, 1200 CC engine, small bumpers, early aprons, etc...  This is not one.
Now, Brazilian cars were all small window cars to the end of production in 1987 and never had IRS. VW, basically continued the production of 1964 models with modern updates. Its not a Mexican Beetle because they too were the same small window cars until '73 or '74 then went to the larger window model but kept the swingaxle till the end of production in 2003.
It could be a Canadian car due to the swing axle, but my bet its a European model brought over by someone in the Militiary Service. VW did not put the IRS setup on the Beetle. The unpadded dash and lack of exterior chrome makes it a low optioned car. All US deliveries were Deluxe models, but the Europeans could delete equipment to reduce the price and save money.
Heinz57
Number of posts : 374
Post by Rwflyboy on Thu Apr 30, 2015 8:57 pm
I posted this on www.volkzone.com and got a response from an Englishman.... this made me think it came out of an Italian area. What is your thought "Heinz57"?
"Those turn signal lenses are an Italian thing are they not?
http://www.thesamba.com/vw/forum/viewtopic.php?t=369459 "
Rwflyboy
Post by type4revolution on Thu Apr 30, 2015 9:21 pm
Def has 67 wheels and hub caps
Post by type4revolution on Thu Apr 30, 2015 9:28 pm
How many sunvisors did it have
Post by Rwflyboy on Thu Apr 30, 2015 9:28 pm
two.... vin #119
Rwflyboy
Post by Heinz57 on Thu Apr 30, 2015 9:29 pm
Yes I believe we have a winner , here is an Itailian turn signal photo, the only difference is the small window on the chrome cover should have an amber color with a clear front. I believe they sell an all clear and solid amber lens that are interchangeable, the Italian ones may have had that small side part sprayed with a transparent paint over a clear lens. The rear tail lights should have amber upper turn signal, but most likely were changed when it was brought over.
Heinz57
Post by Rwflyboy on Thu Apr 30, 2015 9:33 pm
That is what I have thought... be nice if there was an easy way to find it "for sure".
Rwflyboy
Post by type4revolution on Thu Apr 30, 2015 9:37 pm
Badge should say made in something . Europe had some bugs make in Yugoslavia. Basic cars no frills and came with one visor and no glove box lock ect
Post by Rwflyboy on Thu Apr 30, 2015 9:42 pm
Rwflyboy
Post by Rwflyboy on Thu Apr 30, 2015 9:44 pm
Look at the badge.. Made in Germany, no weight numbers at the bottom, no badges I have seen have the D2 after the 11 in upper corner, Model 1220? can't find a model 1220
Rwflyboy
Post by type4revolution on Thu Apr 30, 2015 9:56 pm
Does it have original 40 HP motor
Post by Rwflyboy on Thu Apr 30, 2015 9:58 pm
No it does not have the original motor. Has a 1971 AE 1600 SP motor. Chassis and body numbers match.
Rwflyboy
Post by type4revolution on Thu Apr 30, 2015 10:11 pm
Def not Mexican or Brazil they would say that if so. This is a euro bug for sure a Heinze 57 of sorts. Nice ride reminds me of a servicemans special.
Post by Rwflyboy on Thu Apr 30, 2015 10:27 pm
Thanks! I am enjoying her... a fun car to drive.
Rwflyboy
Post by Attorney Isaiah Loophole on Fri May 01, 2015 10:09 am
Awesome car!
Number of posts : 4930
Post by Rwflyboy on Fri May 01, 2015 11:07 am
Thank You! Time to start on taking care of the little pesky things it needs.
Rwflyboy
Post by Heinz57 on Fri May 01, 2015 4:38 pm
You can order a Birth Certificate from VW directly in Germany. The BC will show the date of manufacture, owners name if it was an ordered car, dealer it was shipped to and of course country of original, which we believe to be Italy now. It will also provide the original engine number, color (exterior and interior), and the options that were installed.
Heinz57
Post by Rwflyboy on Fri May 01, 2015 5:44 pm
I am going to sit down and do that tonight.. up to 8 months to get them... hopefully sooner.
Rwflyboy
