Kadrons with scat linkage setup from the kaddieshack
Post by pwmcguire on Fri Jan 16, 2015 4:25 pm
So I picked up some dual Kadrons that needed some work. I did a lot of research mostly provided by the Kaddieshack. I just didn't like the way they put the return spring under the screw. I came up with this, I used a motorcycle chain master link to make a bracket. It doesn't move it too far off of the carb, I drilled the one end a little larger to accept the carb screw. Its hardened so it wont bend. It looks so much better. The only thing unknown is the torque that it will place on the carb body where the screw is. I'll follow up next winter.
Number of posts : 786
Re: Kadrons with scat linkage setup from the kaddieshack
Post by jim conner on Fri Jan 16, 2015 7:30 pm
Cool Mod. I will do this to my set. Thanks Jim
jim conner
Number of posts : 166
Post by type4revolution on Fri Jan 16, 2015 7:37 pm
Torque on screw is negligable should not be a problem. With treated and hardend chain dissimlar metal should not be to much of an issue either.
Post by pwmcguire on Fri Jan 16, 2015 8:37 pm
type4revolution wrote:Torque on screw is negligable should not be a problem. With treated and hardend chain dissimlar metal should not be to much of an issue either.
My thoughts too, but it is still a question in my mind
