Ict velocity stacks
Page 1 of 1 • Share •
Ict velocity stacks
Anyone seen velocity stacks for weber ict carbs for sale anywhere? Or maybe even modified some to work?
I'd like to have them on mine, but haven't seen any. It's no race motor, just a daily, but I do like the clean look of them.
henry70- Dub Noob
- Number of posts : 7
Registration date : 2013-07-01
Re: Ict velocity stacks
Here are some that would probably work fine. Neck on a ict should be around 52 mm. Just do a generic search for velocity stacks with a 52 mm base.
http://www.ebay.com/itm/Carb-Velocity-Stack-44mm-50mm-52mm-55mm-/141311203285
Attack chicken- Dub Nut
- Number of posts : 104
Gabass- Dub Nut
- Number of posts : 350
I ordered the DCOE stacks (simular) from my local fella in Dalton.
they were steel and worked well (empi).
IIRC the DCOE and ICT stacks are the same, I may be wrong, but I think I am right.
Are you doing a single center mount install or a dual install?
I only ask because I have a bunch of jets and a couple of sets of venturis.
There is only enough to do one carb though.
The imulsion tubes are different, but the jetting is the same in the DCOE and the ICT.
-Just rambling...
-Just rambling...
ASBug- Dub God
- Number of posts : 2185
Thanks for the help guys. I couldn't find much out there myself. And it's for a dual set up on a 1776
henry70- Dub Noob
Page 1 of 1
