Oil spray in the engine compartment
Post by 39coupe on Thu Jul 31, 2008 8:35 am
I know this is a tuff topic without being able to see the car but here goes.
My '65 1200 40hp is spraying oil everywhere in the engine compartment. Can't seem to find where the heck it is coming from. The way it is spraying it is getting into the pully or belt somewhere. So my thought is that is coming from around the crank pully. Any other thoughts?
39coupe
Number of posts : 455
Re: Oil spray in the engine compartment
Post by Attorney Isaiah Loophole on Thu Jul 31, 2008 3:21 pm
I would say look around the distributor, fuel pump, oil filler, and pulley. Since you have a pulley try it but if it is that you might need a sand seal pulley.
spraying oil
Post by jim conner on Thu Jul 31, 2008 6:18 pm
Frist thing I would do is clean that old girl up good, Put a plastic bag over the dizzy, spray a little water on the engine then some spray engine cleaner. Then let it sit for about five minutes hit it with the high preasure garden hose again,remove the bag and then lite her up. As Bryce stated a lot of leaks come from old dizzy seals which sell for about $1.00 Hope this helps Peace...Jim
jim conner
Number of posts : 172
Post by 71_georgia_beetle on Thu Jul 31, 2008 9:07 pm
Make sure the seal on the oil sensor is good. Oil leaking from there has a quick route to the pulley well.
Post by vwovalchild on Fri Aug 01, 2008 9:56 pm
Do clean up the engine and run it after it is clean and dry. I would look closely at the oil preasure switch or oil cooler seals. if its spraying these are the two areas that are presurized.
Post by EngineerTEN on Sat Aug 02, 2008 10:43 pm
Also look for leaking around the oil cooler.
EngineerTEN
Number of posts : 358
