76 Westy- which accessories connect to fuse holder #9?
Post by Rwflyboy on Thu May 29, 2014 9:41 pm
Looking at my electrical system and ignition. The key was stuck in the ignition when we got the bus a couple weeks ago for one. We used penetrating oil on it and it came out finally and it matches all the locks. Yeah! So we ordered two keys from veedubkey.com site. If u know have your original key and you can read the key code he can cut you a key for $10. They had installed a Briggs and Stratton ignition to  bypass the original key... So it's time to get the original ignition hooked back up. But it is a "mouse nest" up under the dash with wires going everywhere..When looking at the "block style" fuse holder designation list from ratwell.com, it just shows "accessory" for fuse holder #9. Is there a sub list for those accessories?
Rwflyboy
Number of posts : 56
Registration date : 2014-04-13
Re: 76 Westy- which accessories connect to fuse holder #9?
Post by Greg on Fri May 30, 2014 8:19 am
"accessories" is kind of a generic term meaning anything the PO needed power for. As such, there won't be a list. You may want to take the wiring diagram below to a printing shop and have it blown up and laminated. I forget where fuse 9 gets power from but the diagram will help you sort out the rats nest.
http://www.thesamba.com/vw/archives/info/wiring/baybus_76.jpg
Greg
Number of posts : 118
Post by Rwflyboy on Fri May 30, 2014 10:41 am
Thanks Greg. I think I will just start trying to trace wires from the fuse "box" back to where the PO's took them.... after I put on the missing cabinet latches/new sink pump etc in/re-key sliding door and some brake mainenance..... But thanks for the wiring scheme!!!
Rwflyboy
