1970 Bay "Hickory"
1970 Bay "Hickory"
Post by johnvalkennedy on Wed May 14, 2014 12:45 am
Picked him up a couple of weeks ago and already went on a 400 round trip adventure. Ran great with 6 passengers and fully loaded with luggage. Mexican blankets cover the mix-match middle and rear but kind-of digging the vibe. Really like the color, not original but close. Seat belts all around with retractables in the front. PO was part of the "Full Moon Bus Culb" near Savannah. He used him to pull his pop-up camper. He stated it had new front seats, transmission, brakes, tires and clutch. Installed a new starter, battery and wood floor. Has a little bit of rust here and there that will need some attention. Hopefully in the near future, I'll be able to afford to lower him a bit, NOT slammed, but low enough to level him out and fit in the garage without propping up the door. I'm real happy that I found a running, driving, stopping bus that doesn't need a complete retoration and that the wife thinks is "handsome".
http://illiweb.com/fa/pbucket.gif?sort=3&o=16
johnvalkennedy
Number of posts : 124
Registration date : 2010-08-21
Re: 1970 Bay "Hickory"
Post by bakertim2 on Wed May 14, 2014 2:09 am
Very nice.
Post by fluxcap on Wed May 14, 2014 4:23 am
That's awesome John! Great looking bus, glad you finally found one.
Post by Attorney Isaiah Loophole on Wed May 14, 2014 10:12 am
Wow sweet bus! You will definitely enjoy it!
Number of posts : 4930
Post by ridikas on Wed May 14, 2014 3:37 pm
Nice Bus!
Post by johnvalkennedy on Wed May 14, 2014 4:02 pm
Thanks I'm happy with the bus and look forward to tinkering to make it "mine".
johnvalkennedy
Post by pwmcguire on Wed May 14, 2014 6:17 pm
Nice, Ill be looking for it in Kennesaw
Post by Rwflyboy on Wed May 14, 2014 8:16 pm
Nice find man! Thinking u will be having a great time with this one.
Rwflyboy
Number of posts : 56
Registration date : 2014-04-13
Post by Jon65 on Tue May 27, 2014 3:23 pm
Looks great!
Post by johnvalkennedy on Tue May 27, 2014 7:48 pm
Appreciate it guys! Guess I'm bringing it to YUBuggin!
johnvalkennedy
Post by Murdock00 on Wed May 28, 2014 7:41 pm
Looks great, and look forward to what you do to it
Murdock00
Number of posts : 53
Registration date : 2013-05-22
Post by johnvalkennedy on Tue Oct 14, 2014 10:20 pm
Wow, it's been a little less than a month ago when I pulled the engine because of some slippage. Come to find out the pressure plate collapsed due to a bad throw-out bearing arm was re-welded?!? This caused the throw-out bearing to be off center with the pressure plate. I installed a new throw-out bearing arm, new bearing and seals. Thanks to Tim Baker and Will, got the fly wheel nut off to replace the main seal, clutch and pressure plate AND got the engine back in the bus. You guys are AWESOME!!! Thanks again!! Because the drive axle's were toast, shocks and tie rods I think were original, I replaced them too. Oh yea, installed a new accelerator cable as well. Got the bus all put back together and on Monday got an alignment done and drove him all day!!! Considering I only had a couple of hours every other day to work on him, pretty stoked to have him back on the road as quicly as I did and driving straight!!
johnvalkennedy
Post by bakertim2 on Tue Oct 14, 2014 10:25 pm
Thanks for the props. Glad it's back on the road.
