Brake issue
Brake issue
Post by New 67 owner on Thu Apr 24, 2014 9:00 pm
Brakes went out so I put on a new master cylinder , adjusted and bleed the brakes and still no pedal. Do I need to adjust the rod off the pedal? Any help
New 67 owner
Number of posts : 50
Registration date : 2013-11-24
Re: Brake issue
Post by pwmcguire on Thu Apr 24, 2014 9:07 pm
Adjust the brakes on all 4 wheels out, tight against the drums. Then bleed. Then back them off. Hopefully this works. I personally use a vacuum brake bleeder from harbor freight. They say it shouldn't work, but it has for me. Don't mess with the rod.
Re: Brake issue
Post by type4revolution on Thu Apr 24, 2014 9:20 pm
Not normally how much free play is in your.pedal. should be half to 3/4 inch pedal free play before rod hits master piston. Check for leaks in your system Esp the rear brake line running on the floor. Bleed brake light switch also.
Re: Brake issue
Post by New 67 owner on Thu Apr 24, 2014 9:23 pm
I did replace the line to the rear also
New 67 owner
Re: Brake issue
Post by type4revolution on Thu Apr 24, 2014 10:27 pm
Dig deeper
Re: Brake issue
Post by vw57drvr on Fri Apr 25, 2014 1:52 pm
I wouldnt touch the push rod. Sometimes these new master cylinders can be tough to get to bleed. That is if it isnt defective.
Number of posts : 897
Re: Brake issue
Post by type4revolution on Fri Apr 25, 2014 2:04 pm
Watch your pressure on those bleeders some will blow seals.
Re: Brake issue
Post by New 67 owner on Sat Apr 26, 2014 7:16 pm
What had happened a lady pulled out in front of me I locked the brakes up. Then the next time I tried to stop no brakes. I've put on a new master cyl., line going to rear, bleed every thing, adjusted the brakes and still no brakes if I can't figure this out there will be a 67 bug going cheap
New 67 owner
Re: Brake issue
Post by 60andslow on Sun Apr 27, 2014 12:21 pm
ive had 2 defective master cyls in a row! installed one, no dice, installed.another same thing, installed the third one bam it fixed it. i was having the same problem.
60andslow
Number of posts : 531
Re: Brake issue
Post by Gabass on Sun Apr 27, 2014 1:16 pm
What brand master did you just install?
Gabass
Number of posts : 350
Re: Brake issue
Post by New 67 owner on Sun Apr 27, 2014 5:50 pm
I got it from oriley auto
New 67 owner
Re: Brake issue
Post by type4revolution on Sun Apr 27, 2014 6:31 pm
Stay away from those style parts stores for old school Vw stuff not worth the headache.
Re: Brake issue
Post by Gabass on Sun Apr 27, 2014 8:10 pm
Get an OE brand one. It's made in china but it's the best for the money. The German one is triple the cost.
Gabass
Re: Brake issue
Post by New 67 owner on Fri May 23, 2014 9:16 pm
I've decided to replace everything in the brake system but the pedel and backing plates this will fix my brake problem
New 67 owner
Re: Brake issue
