How much suspension travel with beam adjusters
Post by pwmcguire on Sat Feb 08, 2014 9:36 am
How much suspension travel is there with swayaway style beam adjusters? I'm trying to figure out where to put them for use with dropped spindles.
Number of posts : 786
Re: How much suspension travel with beam adjusters
Post by bakertim2 on Sat Feb 08, 2014 9:38 am
Have you cut the beam yet?
Post by bakertim2 on Sat Feb 08, 2014 9:40 am
I think you get about 3-4 inches of adjustment with those adjusters.
Post by pwmcguire on Sat Feb 08, 2014 9:46 am
bakertim2 wrote:Have you cut the beam yet?
With you asking, this answer frightens me but, YES
Post by pwmcguire on Sat Feb 08, 2014 9:50 am
I have marked where the center of original grub screw was.
Post by Grifspop on Sat Feb 08, 2014 11:20 am
I think what Tim means is that it depends where the adjusters are clocked-
You can use them to raise your car or lower your car depending where they get welded in- I've seen guys with the adjusters welded in the wrong place, and with them set as high as they can go the car is still too low- and I've also seen a car that keeps bouncing because the adjusters were in the wrong place and the shock towers were cut off when it was narrowed
Post by pwmcguire on Sat Feb 08, 2014 11:35 am
That is why I asked how much travel so I know where I want to clock them with dropped spindles
Post by type4revolution on Sat Feb 08, 2014 11:38 am
Just have Tim build your beam all mine work great. You want to use the spindles to get your max drop and fine tune with adjusters. It wlll work and it will ride like a caddy with or without shocks.
Post by pwmcguire on Sat Feb 08, 2014 12:11 pm
I am building my beam. I just needed some information I could not find.
Post by bakertim2 on Sat Feb 08, 2014 10:05 pm
Give me a call when you can. Maybe I can answer the question better over the phone.
