Coolant Temperature Sensor
Post by ridikas on Mon Oct 14, 2013 10:59 pm
I know this isn't aircooled related, but does anyone know of any websites on how to replace a coolant temp sensor? Can't be that hard, the part was only 8$!
Re: Coolant Temperature Sensor
Post by Heinz57 on Thu Dec 12, 2013 8:32 pm
Are you wanting to change the one for the gauge or the one for the ECU/FI? For $8 sounds like the gauge sensor. Both are simple to remove with a deep well socket. Just drain the coolant down some before you remove the either sensor.
BTW check the VWVortex.com site as well.
Heinz57
Number of posts : 370
Post by sploval53 on Thu Dec 12, 2013 8:47 pm
Call me if u want figure it out
I still have the valve cover gasket and oil pan gasket for it
Post by Heinz57 on Fri Dec 13, 2013 6:50 pm
I would like to help you, but I tore up my left elbow and have a Dr apt on Monday to see how bad I hurt it. May end up in a sling for a while and I drive a Big Rig/flatbed for a living so I am worried about that at the moment.
Have you talked to Tim Baker about a repair? Drew is also into H2O models and knows them well.
Heinz57
Post by ridikas on Fri Dec 13, 2013 6:59 pm
I haven't. Today I washed the car and the overheating light would blink for 5-10 seconds and then go on and off. Im worried if it really is over heating or not. All these sensors on the water cooled is confusing. I'll take a look at it tomorrow
Post by type4revolution on Fri Dec 13, 2013 9:10 pm
Check the Parts Place
Post by type4revolution on Fri Dec 13, 2013 9:26 pm
http://www.partsplaceinc.com/products/search-results.aspx?c=6
Post by ridikas on Fri Dec 13, 2013 10:05 pm
Is this the solution to the light coming on?
