may be getting
may be getting
Post by runabout199 on Sun Sep 22, 2013 8:34 pm
i may be getting a 74 bug with a sun roof. the only issue i see with this car is the sun roof leaks. i know they all leak but does any one know of a place to have this fixed and a price. would need new headliner also. i would just like it to be factory and not gush water, surely there has to be a way to fix it without welding it or puting silicone in it
thanks all
runabout199
Number of posts : 114
Registration date : 2012-01-29
Re: may be getting
Post by vw57drvr on Sun Sep 22, 2013 9:45 pm
They dont all leak.
Number of posts : 897
Re: may be getting
Post by sploval53 on Sun Sep 22, 2013 10:14 pm
I can fix it as long as most of the parts are there. Some are hard to find.
Re: may be getting
Post by Grifspop on Sun Sep 22, 2013 11:50 pm
If you open it up, you should see some drain tubes in the front of the opening- make sure that they're not plugged up with leaves and debris- water gets past the felt seal around the steel panel, but is supposed to drain out the front and rear of the mechanism and down the pillars. If they're clogged, there's no where else for water to go but inside the interior
Re: may be getting
Post by ridikas on Mon Sep 23, 2013 1:53 am
If it's missing parts the replacements are very expensive, and some parts they don't make new anymore! Good luck!
Re: may be getting
Post by vw57drvr on Mon Sep 23, 2013 3:57 pm
Parts may be a little high, but you will only have to buy them once. Properly adjusted and lubed they will work great for years. I wouldnt let a sunroof scare me away.
Re: may be getting
Post by sploval53 on Mon Sep 23, 2013 4:09 pm
I have had about 4 metal roof cars. Love um. Work well when built right.
Re: may be getting
Post by runabout199 on Mon Sep 23, 2013 7:08 pm
well got the car sun roof isnt my concern any more, my heat risers have rusted through and my car lacks power, any help would be nice. its a 1600 dual port. 34 pict carb.could this be the clutch going out? seems to not slip and it is real sluggish just reving it from carb. also it does not want to start back up when its warm. please please help thanks
runabout199
Re: may be getting
Post by ridikas on Mon Sep 23, 2013 7:22 pm
Let's see some pics of that beetle!
Re: may be getting
Post by Bugman114 on Tue Sep 24, 2013 8:05 am
Check your points gap and adjust valves.
Re: may be getting
Post by runabout199 on Wed Sep 25, 2013 8:55 pm
runabout199
Re: may be getting
runabout199
Re: may be getting
Post by runabout199 on Wed Sep 25, 2013 8:56 pm
runabout199
Re: may be getting
runabout199
Re: may be getting
Post by runabout199 on Wed Sep 25, 2013 8:57 pm
runabout199
Re: may be getting
Post by runabout199 on Wed Sep 25, 2013 8:58 pm
there she is cheers
runabout199
Re: may be getting
Post by runabout199 on Wed Sep 25, 2013 8:59 pm
runabout199
Re: may be getting
Post by runabout199 on Wed Sep 25, 2013 9:01 pm
sploval53 wrote:I can fix it  as long as most of the parts are there.   Some are hard to find.
i think its complete just not working. when i try to use the handle the roof will move a very little then it just clicks. tried both directions. im clueless on sunroofs but positive on duck tape hehe Very Happy
runabout199
Re: may be getting
Post by ridikas on Fri Sep 27, 2013 10:22 am
Looks solid! Sweet color!
Re: may be getting
Post by fluxcap on Fri Sep 27, 2013 11:25 am
Bob (anybody remember that guy???) did a write up on the samba about taking apart a sunroof and fixing it. May be worth a read. http://www.thesamba.com/vw/forum/viewtopic.php?t=379367&highlight=sunroof
Re: may be getting
Post by 60andslow on Fri Sep 27, 2013 11:33 am
im in cartersville also off felton and grassdale. if u need any help just let me know.
60andslow
Number of posts : 531
Re: may be getting
Post by runabout199 on Fri Sep 27, 2013 10:32 pm
fluxcap wrote:Bob (anybody remember that guy???) did a write up on the samba about taking apart a sunroof and fixing it. May be worth a read. http://www.thesamba.com/vw/forum/viewtopic.php?t=379367&highlight=sunroof
thanks
runabout199
Re: may be getting
Post by runabout199 on Fri Sep 27, 2013 10:33 pm
60andslow wrote:im in cartersville also off felton and grassdale. if u need any help just let me know.
thanks i work at gerdau formerly birmingham steel im on grassdale all the time. i live 12 miles from there Very Happy
runabout199
Re: may be getting
