Not sure, but something is out of whack.
Post by Cdub on Wed Aug 28, 2013 2:02 pm
Hello, I am very new to Vw's and mechanics in general. I have a 1973 super beetle with a 1971 dual port 1600, standard single vacuum distributor and a 30 pict 2 carb.
That I was given as a trade. It was in pieces as far as wiring, I replaced the main loom all ignition components and rebuilt the carb.
It will barely idle and has little power when I drove it around the block.
Not sure what the issue is.
Any help would be greatly appreciated.
Cdub
Number of posts : 10
Registration date : 2013-08-24
Re: Not sure, but something is out of whack.
Post by sploval53 on Wed Aug 28, 2013 2:06 pm
Check the firing order and make sure the vacuum line s not clogged up
Post by aircooledaddicts on Wed Aug 28, 2013 3:33 pm
A few things I would check are timing, valve adjustment, and points
Post by Cdub on Wed Aug 28, 2013 4:22 pm
I have checked the timing the static way and I put a straw in the #1 plug hole, I noticed it went around to TDC twice and my button is lined up with one. I set the valves to .006 and the points to .016. Could a faulty or clogged exhaust cause this?
For my distributor and carb single vacuum and 30 pict 2 where does the vacuum line go? I currently have it on the left side of the carb.
Cdub
Post by Cdub on Wed Aug 28, 2013 4:29 pm
Sorry, thank you for such quick responses!
Cdub
Post by Cdub on Wed Aug 28, 2013 9:53 pm
Is there anyone that lives near Sugar Hill that could help me troubleshoot?
Cdub
Post by ASBug on Thu Aug 29, 2013 9:07 am
aircooledaddicts wrote:A few things I would check are timing, valve adjustment, and points
X2 in that order.
