More starting issues.
Post by ridikas on Sun Aug 25, 2013 9:30 pm
I went to go get grocerys today at walmart, came back to my apartment and realize that i forgot butter to cook the chicken. So I went back out to my car to start it, and I got the dreaded click and no start sound. I just put a new starter in it probably about a month and half ago, so I think the starter is fine. I checked the wires to it and both are snug on there. Could there be teeth missing on the flywheel and every once in awhile it get stuck in one of those spots and does not want to start? I've been having this issues ever since I've had the car and can never seem to figure it out. Push starting on some of these hills in Milledgeville really isn't a issue unless I'm facing up hill. lol!
Re: More starting issues.
Post by aircooledaddicts on Sun Aug 25, 2013 9:36 pm
Could be the ignition switch itself. They are known to go bad. They are just plastic and wear. I would start there
Post by ridikas on Sun Aug 25, 2013 9:37 pm
I replaced the old switch the same time I replaced the starter. Do you think it can go bad that fast?
Post by Attorney Isaiah Loophole on Sun Aug 25, 2013 9:50 pm
Put a starter relay on it
Last edited by Attorney Isaiah Loophole on Mon Aug 26, 2013 10:41 am; edited 1 time in total
Post by 60andslow on Sun Aug 25, 2013 9:53 pm
ive got plenty of brand new parts that were defective or bad and did not last long. u can arc the wires that plug in the switch to see if its the switch itself
60andslow
Number of posts : 531
Post by ridikas on Sun Aug 25, 2013 9:55 pm
I'll order a new ignition switch.
Post by sploval53 on Mon Aug 26, 2013 12:05 am
Put a push botton in somewhere
Post by Greg on Mon Aug 26, 2013 10:06 am
There is a way to by pass the switch altogether for testing, I had to do this on mine until I replaced my switch. Look under the back seat, there should be a plastic wire connector. Make sure it's the wire that goes to the starter, unplug it, then take a length of wire and connect the wire leading to the starter to the battery, if it spins the starter, it's the switch.
Greg
Number of posts : 118
Post by type4revolution on Mon Aug 26, 2013 10:29 am
Put a hard stary Relay in it late model cars wiring suck after 30 plus years.Napa St1 that will fix it
