1960 VW Beetle - Bagged
Page 1 of 14 • Share •
Page 1 of 14 • 1, 2, 3 ... 7 ... 14
These are pictures of my 1960 Beetle - 1600 DP w/ Dual 34 ICT Webbers - Airbags in the rear and Air Shocks in the front. Low - the pan sits on the ground - Raised - it is above ride hight.
[img]
[/img]
[img]
[/img]
[img]
[/img][img]
[/img]
EngineerTEN- Dub Nut
- Number of posts: 358
Registration date: 2008-07-29
Re: 1960 VW Beetle - Bagged
Sweet ride. What tires are you running?
Attorney Isaiah Loophole- Dub General
- Number of posts: 3205
Registration date: 2008-07-20
Wow, that looks awesome! Is the rear window art painted?
Damn-it Don- Out of Control Dubber
- Number of posts: 1432
Registration date: 2008-07-25
I can't wait to see it in person. It looks really good.
aircooledaddicts- Out of Control Dubber
- Number of posts: 1499
The tires are Nankang 135 R15 72S N-803. I'll be replacing them next spring. I dont like the wheels and I'm probally going to be replacing them with the stock style chrome wheels. 5.5s if I opt for performance tires. I woule really love to do whitewalls on the chrome wheels. However, I have never seen it done before and I am not sure what it will look like on the car.
The rear window was airbrushed. The paint was really warn so I removed it in preparation for an Aircooled Addicts sticker.
Thanks Gary - You should see it Saturday. I planned to quickly sandblast the rear drums this evening before putting them back on the car but it was raining when I got home from work. I purchased new brake components all arround for a 100% new brakes on the car. Promlem is the new drums fit too tight and rub on the dust plate and the hub dosent turn at all once I get the axle nut on. The old drums work just fine - turn freely as it should with the axle nut on. Looks like I'll need a small spacer to get the new drums to work. So for now - I am going to clean up the old drums and use them until I resolve the issue with the new drums. I'm really looking forward to getting the car back on the road after sitting in the garage for the last few mionths.
Woo Hoo!!
Here are some older pictures over the last few months as I was working on the car:
The picture below is the rear of the car after I removed the engine. You can see the rear airbags and the custom mount in the picture.
Here is my engine on the floor. It was nice to see that the heads were ported and polished.
I found receipts with the car that showed and engine rebuild in 2003. I was curious of the condition of the engine and what size it is. The block is a 1967 vintage. Pistons are 85.5mm. So it is basically a 1600 dual port. Rods were still tight and there was very little wear on the cylendars and pistons. Heads and valves were good with the exception of one exhause valve which was too tight. The exhause valve was slighty open when the engine fired which caused alot of carbon build-up around the seat. I've got that adjusted correctly now. The picture below is during the tear-down for inspection.
Here I am with my transmission. You can see the mounts for the airbags. I replaced the gaskets, seals, boots, bearings, completly sandblasted it and painted it flat black. I also replaced the nuts with stainless steel nylon lock nuts. I did nothing with the gears since it was working perfect before I pulled it. It went back in with new rubber mounts. It had a offroad mount kit on it that had no rubber. It is nice with the rubber - most of the vibration is gone.
This past Saturday my wife and I took the beetle up to the the Aircooled Addicts meet. We were nearly there when we were stranded under the cover of a service station due to the storm. Once things cleared up we headed home. The picture below is what we found - the storm downed a tree over the windshield of my wifes car.
Below is pictures of how the suicide doors were done.
The door handles were relocated towards the front of the doors.
The hinges were relocated to the rear of the doors.
The door mechanism was moved to the front of the door. Good idead - however, they did not make it adjustable which is a pain.
Below are pictures of the hinges that were moved to the rear of the doors. I don't much like how this was done here - like it was never completed or done right in the first place.
Here is the work done on the A pillar.
Car is looking good. That stinks about you wifes car. Atleast it wasn't the bug though. Thats how I lost my 67 bug, I woke up one morning after a storm to our huge tree in our front yard laying right across the roof.
"We were nearly there when we were stranded under the cover of a service station due to the storm."
One of those bugs that melts when it gets wet?
bumblebuggy- Out of Control Dubber
- Number of posts: 1502
Registration date: 2008-07-24
No - it is not yet prepared for rain. Decklid is removed, wipers are not yet working and I am still working on the door seals.
I am looking for a set of those rims, are you still planning on getting rid of them? If you do Ive got dibs
I love your car, one day mine will be as clean as yours is, all it takes is some time and of course $$$$$$$, Im glad is a lot cheaper than resoring most cars
59suicide- Dub Crazy
- Number of posts: 550
Registration date: 2008-08-03
If you want them, I'll sell you the rims complete with tires and lug nuts for $400 or I will trade for 2 of these (front) http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D6620
and 2 of these (rear) http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D6620
I have a set of the wheels you are looking for. They are all 5.5 wide, but I'm only asking $180.00 for all including hubcaps. I'll have them at the show at All Around Restos if you (or anyone else) wants to see them.
Jon
www.athensvwclub.com
Jon
Hobug- Dub Crazy
- Number of posts: 629
Registration date: 2008-07-22
I am not going to make it to the show but I am interested. What condition are the wheels in? Can you post pictures?
Thanks,
Thanks,
Similar topics» 1960 Cadillac
» Bantam Champions 1960-63??
» 1960 VW Beetle - Bagged
» 69 bug bagged
» Otis - my '65 Beetle
» 69 bug bagged
Page 1 of 14
