1st engine drop sanity check - done! (with a few pics)
Post by ultralite on Sat Aug 17, 2013 5:02 pm
Been a long day working on 2 different cars. But, I started the prep for the '69 Westy engine drop.
Planning to pull engine only, NOT transmission. I do not have a transmission support bar. So, I'll need to jack the transmission correct? Or else it will come down with the engine once I start to lower, right?
Vehicle is up on jack stands but my vision is very limited. Trying to give myself a check here before I make a big mistake. I see the frame mount at the front of the transmission and I felt around the bell housing for anything else.
The Bentley instructs to install the transmission support bar, which I don't have.
Last edited by ultralite on Sun Aug 18, 2013 3:23 pm; edited 1 time in total (Reason for editing : status change)
ultralite
Number of posts : 181
Re: 1st engine drop sanity check - done! (with a few pics)
Post by Hobug on Sat Aug 17, 2013 5:56 pm
I usually use a ratchet strap to hold the trans in place. You can also use a jack or jack stand.
Number of posts : 1310
Post by ultralite on Sat Aug 17, 2013 6:08 pm
Thanks man. Had some supper and now back at it with my daughter helping me.
My Bentley manual doesn't say to unbolt the bell housing. But surely I have to right?
ultralite
Post by Hobug on Sat Aug 17, 2013 6:27 pm
Just the four bolts that hold the engine to the trans. Remember fuel line and electrical connections, accelerator cable and heater cables. Slide it out.
Post by ultralite on Sat Aug 17, 2013 7:34 pm
Yep, I've disconnected everything but the last bell housing bolt. That will have to be tomorrow. What a long day it was. Should have kept to one car only for the day.
I've often heard people say how easy it is to drop an engine. I feel lied to....
ultralite
Post by Hobug on Sat Aug 17, 2013 8:31 pm
First couple of times it seems a little daunting, but after that, it gets to be easy. Trust me.Twisted Evil  No really.Cool
Post by ultralite on Sat Aug 17, 2013 8:40 pm
The bolts at the top of the bell housing about did me in. The passenger side top bolt holding the starter threw me off too.
ultralite
Post by ultralite on Sun Aug 18, 2013 3:08 pm
ultralite
