alternator pulley issues
Post by kokodabobo on Tue Aug 13, 2013 12:27 pm
The PO had put in an alternator and one of those cheap chrome pulleys. The pulley rubs against the alt and the belt won't get tight enough. It has about 2 inches of play in it. I started with 3 shims in between and 4 outside and now I've. Put all on the outside but the belt is still loose. I checked the belt size and its right, it just seems like there should be a spacer or something behind the pulley so the nut can tighten down properly. Has anyone had this problem before or have any advice?
kokodabobo
Number of posts : 303
Re: alternator pulley issues
Post by DiggerD on Tue Aug 13, 2013 12:45 pm
The answer is right in your post. Replace the cheap chrome pulley with a good Original German one. They are notorious for problems such as this.
Post by vw57drvr on Tue Aug 13, 2013 1:31 pm
Also, there is a bushing on the front and rear to keep the fan and the pulley from hitting the body of the alternator. The last rebuilt unit I bought was missing the one on the rear.
Number of posts : 897
Post by kokodabobo on Tue Aug 13, 2013 2:07 pm
Are there german pulleys that fit? I know on generators the center of the pulley is a circle but on my alt it is straight with rounded edges and the pulley has to be specific to it. And does anyone know what I would need to shop for to find that bushing?
kokodabobo
Post by vw57drvr on Tue Aug 13, 2013 2:31 pm
Here is the pulley at aircooled.net. The alt and gen pulley should interchange. Everyone I have seen has that hole with flat sides. As far as the bushing, I am not sure where to get them. I always just took the old ones out of the old alternator. The link below is just for illustration. I never use pulleys without the two notches like original.
http://vwparts.aircooled.net/Alternator-Generator-Pulley-12-Volt-043-903-109-p/043-903-109.htm
