dashboard light replacements
Post by jotty on Fri Aug 09, 2013 5:25 pm
I got a 64 bug and I cant seem to find the replacement bulbs anywhere??...any help would be awesome
jotty
Number of posts : 137
Registration date : 2013-07-16
Re: dashboard light replacements
Post by Gabass on Fri Aug 09, 2013 6:45 pm
I've got 6 volt and 12 volt bulbs for $1 each. Have the light sockets too if they break when you pull them out.
Gabass
Number of posts : 350
Post by fluxcap on Fri Aug 09, 2013 6:55 pm
Oreillys is the only local auto parts store I've found them at.
Post by jotty on Fri Aug 09, 2013 8:03 pm
Thanks bro ...I'm heading there now..I appreciate it!!
jotty
Post by ping349n on Fri Aug 09, 2013 8:23 pm
fluxcap wrote:Oreillys is the only local auto parts store I've found them at.
Do they have those in 6V?
ping349n
Number of posts : 344
Post by fluxcap on Fri Aug 09, 2013 9:19 pm
Probably not Brian. Have to get them from Wilson or online someplace.
Post by ping349n on Fri Aug 09, 2013 9:33 pm
That's what I figured. I know most of the flaps have 6V headlight bulbs.
ping349n
Post by pwmcguire on Sat Aug 10, 2013 9:40 am
I've got some small 6 volt bulbs from oreilys before. I'm not sure about speedometer bulbs
light bulbs
Post by mrfeather on Sat Aug 10, 2013 11:46 am
I have been looking to put LEDs in mine there is a company on Mountain Industrial in Tucker called Atlanta Light Bulb. They had the standard bulbs as well.
http://www.atlantalightbulbs.com/default.asp
mrfeather
Number of posts : 176
Post by pwmcguire on Sat Aug 10, 2013 12:57 pm
If you are creative and can solder, its nothing to make led lights for a speedometer using 6 volts. this is one I built for 12 volt and I have built some for 6 volt but I can't find one right now. Search for an led resistor calculator to figure out what resistor to use. The resister is in the holder surrounded by an epoxy putty, which glues it in place. If you want to make easier use a foam ear plug as a holder. If I had access to the holders I'd make them and sell them.
Post by pwmcguire on Sat Aug 10, 2013 1:02 pm
mrfeather wrote:I have been looking to put LEDs in mine there is a company on Mountain Industrial in Tucker called Atlanta Light Bulb. They had the standard bulbs as well.
They do not work with oil pressure and generator. I assume because of the way the lights are activated in the circuit, backlight and high beam, I think, turn are no problem. back light is awesome because you can change the color and make it brighter. My white 73 Baja had green accents.
