Oil dripped after change.
Post by ridikas on Tue Jul 30, 2013 10:48 pm
I changed the oil in my bug today, put everything back together, wiped the underside and went back inside the house. Came back outside 3 hours later and saw a couple drips of oil. Is that normal?new gaskets and strainer too.
Re: Oil dripped after change.
Post by sploval53 on Tue Jul 30, 2013 10:51 pm
U put new copper rings around the studs and drain plug
Post by ridikas on Tue Jul 30, 2013 10:53 pm
Yeah
Post by sploval53 on Tue Jul 30, 2013 11:00 pm
Where is the oil coming from
Post by ridikas on Tue Jul 30, 2013 11:04 pm
The drips don't line up with the sump plate. I'll look in the morning
Post by DiggerD on Tue Jul 30, 2013 11:18 pm
Since the drips don't line up with the plate, maybe you spilled a little bit when filling and it just worked down around the cylinder tins?
Post by ridikas on Tue Jul 30, 2013 11:20 pm
It's dry under the sump plate and the drips are offset by a couple inches. Maybe im crazy
Post by Cave Man on Tue Jul 30, 2013 11:24 pm
If there is notmabigger puddle under there in the morning I go with the idea that there was some spill over. Possibly from the draft tube.
Cave Man
Number of posts : 333
