Carb is BONE dry
Carb is BONE dry
Post by ridikas on Fri Jul 26, 2013 12:00 am
Trying to figure out why my Carb is not getting fuel. The pump was working til I took it off to see if it fit my other beetle. I have spark because it fired and ran til it ran out of gas in the bowel. The fuel pump is the one that fits the generator, not the alternator. Also the Carb is a Solex 31/30
Re: Carb is BONE dry
Post by sploval53 on Fri Jul 26, 2013 12:46 am
I can swing by tomorrow if u want. If cant figure it out. Is it your moms car that's doing it
Post by ridikas on Fri Jul 26, 2013 12:53 am
Yeah it's hers. I'll try working on it again tomorrow. Im broke right now, I'll have to wait til I get paid to call you out here.
Post by sploval53 on Fri Jul 26, 2013 1:14 am
Let me know when your at the house ill swig by. Ill help u figure it out
Post by fluxcap on Fri Jul 26, 2013 4:19 am
Are you positive you connected the hoses back to the correct ports when you reinstalled the pump? They may be hooked up backwards.
Post by ridikas on Fri Jul 26, 2013 7:37 am
I tried both ways! I'll post a picture.
Post by ridikas on Fri Jul 26, 2013 4:53 pm
Still not pumping gas in the carb. Talked to Bryce about pouring gas down the throat and seeing if it will fire and re prime the pump.
Post by DOODLE BUGG on Fri Jul 26, 2013 10:27 pm
i just built a motor an it wouldnt pump any i put some gas down the carb an it fired up an pumped up
Post by ridikas on Fri Jul 26, 2013 10:31 pm
I'll try that tomorrow. How much did you pour?
Post by ridikas on Sat Jul 27, 2013 4:41 pm
Poured gas down the throat and now the fuel pump is primed and working. I have spark at the points and still won't fire.
Post by Muffler Bearing on Sat Jul 27, 2013 10:58 pm
I had the same prob after I put a new one in mine. I forget how I fixed it. I will think hard and try to get back to ya. Can you post a pic of the carb to see if its hooked up right? So all you did was remove the pump and put if back on right? Did you leave the pole that slips in the case in?
Post by ridikas on Sat Jul 27, 2013 11:22 pm
Taylor fixed it. Lines to fuel pump were backwards.
Post by Jon65 on Sat Jul 27, 2013 11:59 pm
ridikas wrote:Taylor fixed it. Lines to fuel pump were backwards.
This is usually a common problem that pops up on The Samba sometimes. I know I should've posted this image earlier:x , but here's a diagram that shows the flow directions of common fuel pumps.
This way, if someone comes upon this thread at a later time, it could help them resolve their problem.
Post by ridikas on Sun Jul 28, 2013 12:02 am
The fuel pump on the bug doesn't look anything like these. Thanks for the pic though!
Post by Attorney Isaiah Loophole on Sun Jul 28, 2013 12:13 am
yeah the first decklid I raised to check this picture had the inlet on the bottom and the outlet on the top
Post by sploval53 on Sun Jul 28, 2013 2:26 pm
It has a older rebuildable pump on it
