Turn Signal Question
Post by AirKewled on Thu Feb 05, 2009 10:56 am
I replaced my turn signal not too long ago, and when I went to use it, the left works fine, but the right does not. When I try to use it on the right, the GEN light comes on, and it will not blink at all. The left side does not have that problem and works fine. I am thinking that there is something making contact with some metal inside. Does this sound possible?
AirKewled
Number of posts : 13
Registration date : 2009-01-28
Re: Turn Signal Question
Post by EngineerTEN on Thu Feb 05, 2009 12:02 pm
Check your turn signal relay switch.
EngineerTEN
Number of posts : 358
Post by AirKewled on Thu Feb 05, 2009 12:05 pm
Forgot to mention that I had already replaced that! So that was not it either. It baffles me...
AirKewled
Post by fearthefat138 on Thu Feb 05, 2009 1:05 pm
trace the wires they are crossed if the gen light comes on
fearthefat138
Number of posts : 275
Post by rpm750 on Thu Feb 05, 2009 1:15 pm
Grounds, Grounds. When the ground is open the voltage tries to find a way there and it does weird thinks. drunken
Post by 39coupe on Thu Feb 05, 2009 1:40 pm
rpm750 wrote:Grounds, Grounds. When the ground is open the voltage tries to find a way there and it does weird thinks. drunken
Grounds - very good start - I had a similar issue and it was ground related.
39coupe
Number of posts : 455
Post by skunk on Tue Aug 25, 2009 11:37 am
check the blinkin relay..ckeck the ground wires to and from blinkers and make sure you have the rite bulbs
skunk
Number of posts : 218
Post by JOHNB on Tue Aug 25, 2009 1:53 pm
Mine did the same thing.The right taillamp was not grounded good.
JOHNB
Number of posts : 31
Registration date : 2008-08-26
View user profile http://WWW.ATHENSVWCLUB.COM
