Will my tires rub?
Will my tires rub?
Post by jshmnghm on Tue Feb 03, 2009 8:25 pm
Putting 2 1/2 inch dropped spindles on a 70 beetle with stock beam, wheels and tires. Will go at least one click in the rear also. Any rubbing issues with this setup?
jshmnghm
Number of posts : 311
Re: Will my tires rub?
Post by jerryg66 on Tue Feb 03, 2009 8:36 pm
In the front it depends on tire size. The 2 1/2 drop spindles are gonna offset the wheels about a half inch or so. I run a 155-60 on front and mine don't. If you 135 up to 155 you should be ok.
Post by jshmnghm on Wed Feb 04, 2009 6:05 pm
Tires are stock size 165/80/15
jshmnghm
Post by racecar67 on Thu Feb 05, 2009 11:05 am
Yes they will rub. I did the same thing and even went to 145's. with two people in it the tires still rub when you turn.
racecar67
Number of posts : 289
Post by fearthefat138 on Thu Feb 05, 2009 11:20 am
get a narrowed beam Laughing
fearthefat138
Number of posts : 275
Post by Clyde on Thu Feb 05, 2009 5:32 pm
Porsche 914 wheels and early Rivieras tuck under the car enough to eliminate the rubbing.
