Max tire size
Max tire size
Post by ridikas on Sat Jun 15, 2013 10:30 pm
Hey guys I finally have decided on which rims to put on my '73 standard beetle. Here is a link http://www.chircoestore.com/catalog/product_info.php?cPath=415_416_801&products_id=13695
What is the max size tire I can put on all 4 rims without scrubbing? Thanks!
Re: Max tire size
Post by Muffler Bearing on Sat Jun 15, 2013 10:42 pm
Are you planning on keeping the factory stance or lowering it a bit?
Re: Max tire size
Post by ridikas on Sat Jun 15, 2013 10:45 pm
I Like the lowered look but plan on keeping it stock. It has adjustable coil over shocks on it right now. I have them on the highest setting and there is quite a bit of gap that needs filling. I want a wider tire than the stock ones and still sit up high.
Re: Max tire size
Post by Grifspop on Sat Jun 15, 2013 11:02 pm
The link you posted shows a 5 x 130 bolt pattern, and your car is 4 x 130 pattern- that means you need to run adapters Mad or have your drums re-drilled
Re: Max tire size
Post by ridikas on Sat Jun 15, 2013 11:12 pm
Wrong link. I meant to post the 4 by 130mm . No redrilling for me!
Re: Max tire size
Post by ridikas on Sat Jun 15, 2013 11:20 pm
Actually they don't have the 4/130 mm. Only 5/130:shock:. What would I need to do to make them fit?
Re: Max tire size
Post by Muffler Bearing on Sun Jun 16, 2013 7:36 am
I would buy new drums drilled for the correct bolt pattern.
Or find some wheels you like with that pattern.
Re: Max tire size
Post by ridikas on Sun Jun 16, 2013 9:06 am
I wanted to upgrade to disc all the way around. Would they come pre drilled for the 5 bolt pattern?
Re: Max tire size
Post by buggin70 on Sun Jun 16, 2013 11:49 am
yea you can get rotors in 5x130
Re: Max tire size
Post by ridikas on Sun Jun 16, 2013 11:51 am
I haven't looked how much, but do you know how much they would be off the top of your head?
Re: Max tire size
Post by ridikas on Sun Jun 16, 2013 11:59 am
I found one website and they want 70$ a rotor. Is there anywhere cheaper?
http://www.socalautoparts.com/product_info.php/industries-brake-drum-rear-lug-porsche-pattern-5x130-p-13060
Re: Max tire size
Post by buggin70 on Sun Jun 16, 2013 12:02 pm
buy the kit with the rotors included...
Re: Max tire size
Post by ridikas on Sun Jun 16, 2013 12:03 pm
Any any suggestions on websites?
Re: Max tire size
Post by buggin70 on Sun Jun 16, 2013 12:08 pm
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-4121 drop spindles included or you can pic stock spindles
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-4126-KT rear with e brake
you will prob have to narrow the beam to have the wider wheels and the disk brake kit so it dosnt look funny
Re: Max tire size
Post by ridikas on Sun Jun 16, 2013 12:14 pm
Didnt realize how expensive this is going to be:shock:. Disc all the way around does sound nice!
Re: Max tire size
Post by buggin70 on Sun Jun 16, 2013 2:14 pm
you really dont need disks in the rear. i had them just on the front of my bug and it did just fine
Re: Max tire size
Post by type4revolution on Sun Jun 16, 2013 3:45 pm
Do just disk up front and drums in the rear with your fav bolt pattern that's all ya need. Save the cash for the big HP engine
Re: Max tire size
Post by bayboy87 on Sun Jun 16, 2013 3:55 pm
my local tire store i use to get all my tires wether vw , honda , or what not  usually has a way to measure for exactly what you need that way you have no issues . i use to just guess by used ones and ride and always had problems since i had a much lower stance but yet to have problems.   if you are keeping it stock height you shouldnt have issues unless going super wide or with a super big rim.!  new tires always best and are one of the most important things on a car
bayboy87
Number of posts : 246
Re: Max tire size
Post by ridikas on Sun Jun 16, 2013 3:58 pm
I like 195s but not sure if the width will scrub. What is the max width I can have on 5.5 w rims and not scrub?
Re: Max tire size
Post by type4revolution on Sun Jun 16, 2013 4:34 pm
195 is a good width anything over that you start pushing the threshhold on your gas milage and wear and tear 205 is the max depends on backspacing its the key to the correct tire suspension formula.
Re: Max tire size
Post by DOODLE BUGG on Sun Jun 16, 2013 6:24 pm
call buggeyed  they probably have the kit for up front an you can buy drums for the rear
Re: Max tire size
Post by ridikas on Sun Jun 16, 2013 10:44 pm
I'll give them a call tomorrow.
Re: Max tire size
Post by Grifspop on Mon Jun 17, 2013 10:37 am
ridikas wrote:I found one website and they want 70$ a rotor. Is there anywhere cheaper?
These are drums, not discs-
To upgrade to 4 wheel discs gets real expensive, and most folks only put the discs on the front
Re: Max tire size
Post by ridikas on Mon Jun 17, 2013 5:44 pm
Yeah. I don't feel like shelling out 600$ for disc. All I want to do is the cheapest and safest way to be able to get my 5 lug fuch wheels on my bug.
Re: Max tire size
Post by type4revolution on Mon Jun 17, 2013 6:17 pm
Buy the drums and roll it
Re: Max tire size
