axle(trans side) removal - 6rib
Post by kyleb on Sun May 26, 2013 9:51 pm
Hello, I couldn't seem to find a video or anything online to help me figure out how to remove the axles from my trans.
6 rib 091 bus trans - with the 6 bolt axles
Both ends are out of the hub. I can't seem to get them out of the trans.
kyleb
Number of posts : 22
Registration date : 2013-05-26
Re: axle(trans side) removal - 6rib
Post by MRJEL on Mon May 27, 2013 8:55 am
Not sure what you are saying there. If both ends are out of the hub, the axle will be on the floor!
If you mean both axles are out of the WHEEL hubs, but stuck in the transmission hubs, Did you remove those bolts? (on the transmission end of the axles). If yes, just pop the side of the CV joint with a hammer, and it should turn loose. The bolts is all that holds them, but they do get lightly stuck in the flange.
MRJEL
Number of posts : 220
Post by kyleb on Mon May 27, 2013 11:09 am
Yes, meaning each axle is hanging from the trans, no longer attached to the hubs.
Yes, i removed the bolts. Ill try hammering again.
kyleb
Post by MRJEL on Mon May 27, 2013 12:20 pm
kyleb wrote:Yes, meaning each axle is hanging from the trans, no longer attached to the hubs.
If the bolts are out, just pull down on the axles as far as you can. They should release from the tranny. but a gentle whop or two may still be needed. The bolts are all that fastens them.
MRJEL
Post by kyleb on Mon May 27, 2013 12:58 pm
got it. turns out I was being to gentile. One good wack with a hammer did the trick. thanks
kyleb
Post by MRJEL on Mon May 27, 2013 3:57 pm
kyleb wrote:got it. turns out I was being to gentile. One good wack with a hammer did the trick. thanks
Great.
We "gentiles" tend to be to soft anyway! (smiley goes here).
MRJEL
Post by Grifspop on Mon May 27, 2013 6:26 pm
Great.
We "gentiles" tend to be to soft anyway! ( Very Happy ).
Fixed it for ya
Post by MRJEL on Mon May 27, 2013 9:53 pm
Grifspop wrote:
Great.
Fixed it for ya
Preciate dat! How'd you do it? I couldn't find them!
MRJEL
Post by Grifspop on Mon May 27, 2013 10:45 pm
They're on the top bar of the Quick Reply bounce
Post by kyleb on Tue May 28, 2013 1:20 am
haha,
I kant spel good.
kyleb
Post by MRJEL on Tue May 28, 2013 9:17 am
Grifspop wrote:They're on the top bar of the Quick Reply bounce
But they don't come up when you hit "quote" thingy. There's a way I know. Kyle may have trouble speellinng. I'm just compooter stupid!
Anyway, Glad you got your problem solved Kyle!
MRJEL
Post by Attorney Isaiah Loophole on Tue May 28, 2013 9:31 am
Mine are on the right when you hit the quote button..... tongue Laughing
Number of posts : 4929
Post by MRJEL on Tue May 28, 2013 10:39 am
If I weren't so dense, I'd feel dumb right now!EmbarassedShockedclown
All I needed to do was make the page fit the screen!
Thanks! Idea
MRJEL
