runs like crap rant
runs like crap rant
Post by swelchy on Wed May 01, 2013 4:24 pm
im misfiring trying to limp home from union city to paulding... misfiring under low rpm range...checked points and the vac can...weirdness
swelchy
Number of posts : 66
Registration date : 2012-12-17
Re: runs like crap rant
Post by ASBug on Wed May 01, 2013 5:01 pm
Bad spark plug wires?
Points closed,
I've got a million of them...
Post by swelchy on Wed May 01, 2013 8:08 pm
Checked the points on the side of the road... they were fine. I finally got her home.... changed the fuel filter under the car and decided to pull the plugs and have a look... Plugs for cyl 1 & 2 looked fresh and normal... plugs for cyl 3 & 4 have pretty bad Dark Tan deposits.... Cyl 3 plug had so much deposits it had bridged the gap.... hard to explain... the deposits were not black or oily at all nor was it white ash like the cylinder is way hot... but just a bunch of crap building up on them.... took it for a spin and she's good for now but Im wondering about the crap on the plugs
swelchy
Post by Gabass on Wed May 01, 2013 9:30 pm
Maybe running to rich, but only on one head? Do you have a double barrel carb or dual carbs? A stock carb would do the same to each cylinder unless the manifold (or one of the manifolds if it's dual port) is damaged on one side. Or just the head itself.
Gabass
Number of posts : 350
Post by DubDawg2579 on Wed May 01, 2013 9:54 pm
Could the coil cause those symptoms?
Edit: Just saw your message about the plugs.
DubDawg2579
Number of posts : 255
Post by swelchy on Thu May 02, 2013 12:46 am
single port 30 pict2 with the vac only dizzy....i will recheck timing this weekend... i have yet to do a valve adjust on this car... so im gonna try to start there sat morning
swelchy
