Roof Rack Trick ( NEVER SCRATCH YOUR ROOF AGAIN )
Post by mrfeather on Sat Mar 23, 2013 12:28 am
NO MORE KEEPING UP WITH YOUR ROOF RACKS PAINT PROTECTORS
You need to go to Home Depot And in the hard wear isles look for the following parts
1/2 " Nylon Spacers With a hole in the middle a little smaller than the tabs on the feet that go in the gutters
if need be drill them to the diameter that you will need to use a rubber hammer to get them on flush
Then get electrical heat shrink tubing and slide over the Spacer and trim to your liking use a hair dryer to shrink the tubing
You can use any color tubing you want Harbor Freight is the cheapest for the tubing.
mrfeather
Number of posts : 176
Re: Roof Rack Trick ( NEVER SCRATCH YOUR ROOF AGAIN )
Post by bakertim2 on Sat Mar 23, 2013 10:42 pm
Pretty cool trick.
Post by callahan on Sat Mar 23, 2013 11:25 pm
factory style braided fuel hose works well too
Post by jim conner on Sun Mar 31, 2013 6:22 pm
Great idea,keep them coming! SlimJim
jim conner
Number of posts : 166
Post by bakertim2 on Sun Mar 31, 2013 7:27 pm
The problem with the braided fuel hose is that the braids fray real bad. This trick just looks clean.
