Installing Ball Joints
Post by macollins105 on Thu Feb 21, 2013 12:48 am
Hereís a cool tool I built for installing ball joints. If you have a welder it is really easy to make. If you donít have a welder Iím sure you could just use the pipe and beat on it. Here is a photo of a tool I built to install all four of my ball joints.
I went to Home Depot and bought a short six inch long pipe. The pipe is an inch and a half. It was about four bucks. It fits the outer ring of the ball joint perfect for knocking it in without damaging it. The pipe was threaded on both ends so I cut one of the threaded ends off to make it stronger around the ball joint. The key is to use a large hammer and keep the ball joint lined up straight when you start. All four of mine went in without a problem and in no time at all.
I tried using the universal ball joint kit from Oreilly auto parts but the pipes included donít fit the VW ball joints. I thought I would post this to give someone an idea for installing ball joints without a press or expensive tool.
macollins105
Number of posts : 104
Registration date : 2012-05-06
Re: Installing Ball Joints
Post by brucerodz on Thu Feb 21, 2013 8:06 am
Good tech. Thanks for sharing !! cheers cheers
brucerodz
Number of posts : 65
Registration date : 2012-12-22
