points gap on a dizzy?
Re: points gap on a dizzy?
Post by type4revolution on Tue Feb 05, 2013 8:26 pm
Best anti thief device / if its a late model bug it could be a bad ignition switch or lose or bad wire . Check your point gap again and make sure dizzy is seated down on block and spins whenyou turn it over
Post by wagtag on Tue Feb 05, 2013 9:04 pm
720boy wrote:that would be funny! Laughing but we all do stuff like Embarassed
Sounds like it can't be done but I put the button in backwards Embarassed who would have thunk you could iock down the cap with it like that..... That took a few hours to figure out. My all time fav was forgeting to take the rachet off the pulley after adjusting the valves clown That was so much fun I did it twice Mad
wagtag
Number of posts : 46
Registration date : 2013-01-07
Post by redneck_davis on Tue Feb 05, 2013 9:53 pm
Lmao. . I could see that being bad.
redneck_davis
Number of posts : 188
Post by Jon65 on Tue Feb 05, 2013 10:40 pm
wagtag wrote:My all time fav was forgeting to take the rachet off the pulley after adjusting the valves clown That was so much fun I did it twice Mad
Don't worry. I'm pretty sure if I sit down and think about it, I've done something worse. Laughing
Post by type4revolution on Wed Feb 06, 2013 6:47 am
Let see here it a new topic that needs to be added. WHAT not to do to your vw and how I screwed up my vw day by doing somethan stupid. / like checking the generator light with the fan belt off duh huh
Post by m1auto on Wed Feb 06, 2013 7:43 am
ha well yes the rotor is in and there is voltage going to the coil. i have no idea wats wrong Sad
m1auto
Number of posts : 32
Post by bakertim2 on Wed Feb 06, 2013 7:58 am
Make absolute sure to get the wires right when plugging in the electronic module. If you cross them, you'll have just wasted $80. Red to the + side of the coil and the black to the - side.
Post by type4revolution on Wed Feb 06, 2013 8:17 am
15 and one YO
Post by redneck_davis on Wed Feb 06, 2013 8:28 am
type4revolution wrote:Let see here it a new topic that needs to be added. WHAT not to do to your vw and how I screwed up my vw day by doing somethan stupid. / like checking the generator light with the fan belt off duh huh
Lmao. First day i wrkd w jeff. .He gets back out the driver seat after revving it up 10times. Im behind the car looking at the belt free engine. Hes like man the gen aint putting out. . Im scratchin my head like dang this guys pretty good. How doees he know that?
redneck_davis
Post by m1auto on Thu Feb 07, 2013 8:17 am
i put the coil in as how the old one came out. it actually quit on me one day completely. before it quit it would do a bad jumping as if i shifted too early or was turning the ignition off and then back on. it wont even start on ether.
and to add to the other topic i once saw a guy change the alternator belt while the car was running. he stuck a screwdriver in the belt while it was spinning and popped it off then used the handle of the screwdriver to pop the new one on!! hes lucky the screwdriver didnt pop out and hit him in the neck lol.
m1auto
Post by macollins105 on Thu Feb 07, 2013 8:31 am
My most recent dumb VW moment. I thought I might have had vapor lock on my bug. I removed the gas cap and put it on the hood. I then went back to the engine to check the fuel filter. Still no gas.... I then went to the front of the car and opened the hood to look at the tank. The gas cap slid down the hood and got wedged between the windshield and hood. You will never guess which one cracked... Embarassed
macollins105
Number of posts : 104
Registration date : 2012-05-06
Post by type4revolution on Thu Feb 07, 2013 9:11 am
Good by winder
Post by Jon65 on Thu Feb 07, 2013 6:03 pm
m1auto wrote:and to add to the other topic i once saw a guy change the alternator belt while the car was running. he stuck a screwdriver in the belt while it was spinning and popped it off then used the handle of the screwdriver to pop the new one on!! hes lucky the screwdriver didnt pop out and hit him in the neck lol.
https://www.youtube.com/watch?v=BQhfcdQf1QA
Seems dangerously cool.
Post by jim conner on Thu Feb 07, 2013 6:48 pm
When I write I say Dizzy cause I don.t know how to spell Distributor.
jim conner
Number of posts : 172
Post by m1auto on Fri Feb 08, 2013 7:47 am
thats exactly how he did it!! wow i thought he was the only one crazy enough to try it
m1auto
Post by Jon65 on Fri Feb 08, 2013 4:50 pm
Yeah, there's actually a couple videos of people doing that.
Post by m1auto on Sat Feb 09, 2013 6:52 am
i can see many ways that could go horribly wrong
m1auto
