64 beetle "peaches"
Page 1 of 3 1, 2, 3  Next
64 beetle "peaches"
Post by LB Bedwell on Thu Jan 17, 2013 10:59 pm
Finally moved my "uncool" Monte Carlo for this pretty clean 64 seems solid and hope to make it a good driver, got it with a bad generator and tires from 1984 from the OG owners grandson who "aquired it" in his grandfathers estate, this guy saved everything from the original invoice, 3 part owners manual, every GA tag receipt since it was new, the import certificate and all sorts of nicknacks he saved for the last 49 years, definetly proud to own this one and to be able to get it out of the garage and out from underneath the cover.
Re: 64 beetle "peaches"
Post by Grifspop on Fri Jan 18, 2013 12:19 am
Look at all those Big Money Options! Nice score!! Very Happy
Post by pwmcguire on Fri Jan 18, 2013 6:50 am
Nice score, looks brand new
Post by rpm750 on Fri Jan 18, 2013 6:56 am
Seems solid....? Looks perfect to me. Awesome score. Congrats!
Post by Muffler Bearing on Fri Jan 18, 2013 7:13 am
Damn. Can't believe you let the Monte Carlo go. That thing was the cleanest mc I think I have ever seen. At least you got a sweet bug for it. I like it!
Post by Hookdriver on Fri Jan 18, 2013 8:27 am
Looks great!
Hookdriver
Number of posts : 156
Post by bakertim2 on Fri Jan 18, 2013 8:35 am
Very nice looking bug. Too cool to get all the history with it as well.
Post by LB Bedwell on Fri Jan 18, 2013 8:37 am
Muffler Bearing wrote:Damn. Can't believe you let the Monte Carlo go. That thing was the cleanest mc I think I have ever seen. At least you got a sweet bug for it. I like it!
yeah I ve had that Monte since 93 bitter sweet letting it go, but it was time, I believe it was a fair deal, got a few things to work out on this one before its a daily and the monte was driven everyday but it was a monte, not a dub so Ill be able to sleep, kicked myself for letting the 62 go but it was what it was and Im glad its got a good home with Brooks, now the busses have another role model.
Post by Jon65 on Fri Jan 18, 2013 8:40 am
Awesome score. Cool
Post by brucerodz on Fri Jan 18, 2013 9:14 am
Nice find !!! Smile Smile
brucerodz
Number of posts : 65
Registration date : 2012-12-22
Post by LB Bedwell on Fri Jan 18, 2013 9:18 am
Grifspop wrote:Look at all those Big Money Options! Nice score!! Very Happy
yeah I know $70 radio in 64
Post by Grifspop on Fri Jan 18, 2013 10:37 am
The optional Gas Pedal on my Oval cost $4 back in 1957 Very Happy
Post by fluxcap on Fri Jan 18, 2013 11:05 am
Looks awesome Lance!
Post by dlandvw3 on Fri Jan 18, 2013 12:42 pm
That thing is beautiful!
dlandvw3
Number of posts : 479
Post by Guest on Fri Jan 18, 2013 12:49 pm
very nice
Guest
Guest
Post by Damn-it Don on Fri Jan 18, 2013 5:53 pm
Beautiful car!
Post by DiggerD on Fri Jan 18, 2013 9:54 pm
Amazing!!
Time capsule cars like that are getting hard to come by these days!
cyclops
Post by LB Bedwell on Mon Jan 21, 2013 8:52 am
thanks yall, now to work the bugs out of it, I have no oil light on at all and then generator light wont go off with the key on, so I got a used generator and put it on yesterday and it went off, drove it, adjusted the POS pict 34 a bit, and washed it finally, then drove it to dry it and the damn light reappears, going to try another voltage regulator and see what happens, oh the joy
Post by LB Bedwell on Thu Jan 24, 2013 8:37 am
yup the voltage regulator was bad and the oil preasure sensor was bad, drove it to work for the first time today and she did pretty good, definatly pleased so far.
Post by bakertim2 on Thu Jan 24, 2013 8:40 am
That's great to hear. Maybe Wil and I can swing by there today and check it out.
Post by LB Bedwell on Thu Jan 24, 2013 8:41 am
yeah common, Ill be trying to put the vacuum distributor in the camper that i got from Steve Cole to see if that helps her, and if yall are feeling froggy I got my tranny to put back in Playmate Shocked
Post by LB Bedwell on Tue Feb 05, 2013 10:14 pm
changed out what seems to be the OG rag joint, man what a difference, got the carb acting better, so Im gonna put her in the wind tomorrow to work and see how long til another OG something goes
Post by LB Bedwell on Tue Feb 05, 2013 10:28 pm
few shots after getting her all cleaned up
Post by LB Bedwell on Wed Feb 06, 2013 8:40 am
well drove it this AM and it will not idle after its warm, or have any power, it spits sputters and dies if you dont feather the throttle, and sitting in traffic that is lots of fun, at least the e brake works ok, at first I thought it had to be the carb and have messed with it, and messed with it, and had outside sources mess with it, but it runs so perfect cold and will run out if the throttle is open all the way, Im leaning toward the coil, gonna pull one off the one of the busses and try that, got to love working it out Mad
Post by fluxcap on Wed Feb 06, 2013 8:46 am
Check that the cut-off solenoid is working. If not, it will not idle once the choke has warmed up. Unplug the power wire to the solenoid (drivers side of carb). Turn the key to "on", but don't crank it. Then hook the wire up to the solenoid, you should hear a click. Unplug/plug the wire up about 5-6 times and make sure it clicks EVERYTIME.
