12 v flywheel on a 40 horse?
Page 1 of 1 • Share •
i have asked a few people but im not sure and they didnt seem sure?
can you do this?
i know you have to clearance the tranny
can you do this?
buggin70- Out of Control Dubber
- Number of posts : 1956
Re: 12 v flywheel on a 40 horse?
Starter and clutch as well.
Do a forum search on SAMBA. I'm sure someone there has done that.
Why not just use a 6v flywheel?
MRJEL- Dub Nut
- Number of posts : 220
You can do it use a high torque AUTOMATIC starter from a late 70s bug or square you can pick these up at advance good luck/ don't forget your oring
type4revolution- Complete Dub Addict
- Number of posts : 907
you can run a 65 bus flywheel 200mm clutch and run your 6v starter on a 12v system if you dont crank on it for ever it will work good we use to use them on rails
ggaagg57- Dub Nut
- Number of posts : 484
if you do i think you also have to change the starter bushing in the trans.
mike hardigree- Dub Noob
- Number of posts : 78
Registration date : 2012-12-01
That's why type4revolution suggested you use a starter for a semi auto trans they do not use the bushingmike hardigree wrote:if you do i think you also have to change the starter bushing in the trans.
pwmcguire- Complete Dub Addict
- Number of posts : 787
I have done both, used the 12V flywheel with 12V starter on my 40 in my 65. Right now I'm using a 6V flywheel with 6V starter on the 40HP with a 12V system and it cranks up a lot better. But as mentioned you don't want to crank on it for a long time. If you have a 65 or older trans you will need to clearance it for the 12V flywheel.
39coupe- Dub Nut
- Number of posts : 455
We had a '66 Beetle that had been converted to 12 volts- still had the 6 volt starter- tap the key and it starts!!! Like Eric said, you don't want to crank it for a long time and burn it up
Grifspop- Dub God
- Number of posts : 2323
My 66 is converted to 12 volts. I use a 6 volt starter with a 12 volt solenoid and a 6 volt flywheel
Page 1 of 1
