Weird problem I can't figure out. Help
Post by RayWHPH on Mon Jan 07, 2013 8:20 pm
Ok everyone. First off I need a wiper motor for my 68, no wipers when it's raining sucks.
My problem I'm having is sitting and idling, it idles great, as soon as I push the clutch pedal, idle goes up 3-400rpm if not a little more, release the petal it back down to where it should. Any ideas? Any help is appreciated.
Thanks
RayWHPH
Number of posts : 7
Registration date : 2012-12-22
Re: Weird problem I can't figure out. Help
Post by type4revolution on Mon Jan 07, 2013 9:02 pm
Is the engine fixn to fall out / check your mounting hardware where engine meets trans. When you press in clutch your pushing engine back thus make throttle cable tight causing carb to idle up / also check pedal assy
Post by wagtag on Wed Jan 09, 2013 7:06 pm
My pedal set did that , turned out it had came loose
wagtag
Number of posts : 46
Registration date : 2013-01-07
