1961 beetle "josie"
Page 3 of 4 Previous  1, 2, 3, 4  Next
Re: 1961 beetle "josie"
Post by buggin70 on Sun Sep 15, 2013 8:16 pm
well ive gotten alot done should be done this week
just need tires and a battery
Post by Jon65 on Sun Sep 15, 2013 10:05 pm
buggin70 wrote:
Dang, that's low!Shocked
Post by 720boy on Sun Sep 15, 2013 10:59 pm
is it on air ride
720boy
Number of posts : 321
Post by sploval53 on Sun Sep 15, 2013 11:54 pm
It's static. No air except in the tires
Post by buggin70 on Mon Sep 16, 2013 7:41 am
Hahaha yea its static. Bags are for groceries Wink lol. and yea it is low. I see how it is driving may have to raise it a hair
Post by bulldawgdude on Mon Sep 16, 2013 8:24 am
drive SLOW .....................           (0\ ! / 0)
Post by 60andslow on Mon Sep 16, 2013 8:50 am
looking good.
60andslow
Number of posts : 531
Post by 720boy on Mon Sep 16, 2013 11:34 pm
watch out for smallllll rock in the road
720boy
Post by buggin70 on Thu Sep 26, 2013 7:50 pm
i got it running today
follow me on instagram to see it. lol
maybe tomorrow ill take another video.
the gen light is staying on so ill see whats up tomorrow
just a few more loose ends and ill be driving it
Post by fluxcap on Thu Sep 26, 2013 8:43 pm
It's alive!!!
Post by Knumb Knucks on Thu Sep 26, 2013 9:56 pm
Those shoe look just as nasty as the car. Lol!
Post by buggin70 on Fri Sep 27, 2013 7:05 am
Theh are callahans shoes lol
Post by buggin70 on Wed Oct 02, 2013 6:54 pm
Changed the oil and adjusted the valves. 2 of the for sump plate studs wont tighten guess I need a step stud for one the other there is no way to fix it. The hole is too close to the big hole in the bottom of the case so idk what to do about it
Post by buggin70 on Sun Oct 13, 2013 11:26 am
put on an alternater that i had tested at auto electric and a new battery and it still wont charge but i drove it to the dyno day and to the last cruise in for the year
Post by fluxcap on Sun Oct 13, 2013 2:41 pm
That's awesome! Glad you got to drive it to the show. Your dummy light for the speedo is working isn't it? It has to be working for the alt to charge. Is it an internal or external VR alternator?
Post by buggin70 on Sun Oct 13, 2013 6:55 pm
its internal and it works if i ground it out on something it comes on. i still didnt fix the tail lights either lol but thats all small stuff
Post by bakertim2 on Sun Oct 13, 2013 10:11 pm
Check the ground strap at the nose cone of the tranny.
Post by buggin70 on Mon Oct 14, 2013 11:14 am
What would that do tim? My battery is directly grounded to the tranny.
Not being a smart ass just bsking
Post by bakertim2 on Tue Oct 15, 2013 8:33 am
Well, I guess that wouldn't do a darn thing with it wired that way.
Post by fluxcap on Tue Oct 15, 2013 9:15 am
I see where Tim is going with this though.
When you did the "pull the wire and touch it to a ground test", did you use the alternator body for the ground, or something else?
From what I'm reading, your red light isn't coming on at all unless you unplug the wire from the alt and ground it to something else.  This means your idiot light is working.  An alternator that isn't functioning correctly will keep your idiot light on all the time.  If this alternator was definitely tested "good", and your idiot light won't even come on with the key just turned to the on position, I'd guess your alternator isn't grounded.
Of course, if you can pull the wire, touch it to the alt body, and the light comes on, this probably isn't the case.
Post by buggin70 on Tue Oct 15, 2013 3:10 pm
Idr where I grounded it to I think it was the oil cap. So the engine is grounded. I got a new one today but broke the pully. I had this same problem when I put this alternater on my black car. Though the guy saifld it was good hopefully this new one will work so I can get the tails figured out
Post by fluxcap on Tue Oct 15, 2013 3:41 pm
Yeah, it was probably just a bum alternator.
Post by buggin70 on Tue Oct 15, 2013 8:13 pm
when i get the pulley ill see it hope thats all i have to do with that. i just need to figure out the tails. if i had the cash right now id get the led ones but unfortunately i dont have the spare cash
Post by 60andslow on Tue Oct 15, 2013 8:29 pm
I got New bulbholders and made a seperate ground for my snowflakes and made it alot eaiser.
60andslow
Post by buggin70 on Wed Oct 16, 2013 7:00 am
I got new buld holders ill just have to make seperate grounds like you and eric said
