Brake pedal won't come up
Page 1 of 1 • Share •
Brakes work, return spring is fine, master cylinder seems to be fine. I'm running out of ideas as to what is causing it. Once you press it down it just stays and feels stiff and resistant. any help or ideas of things i could do to fix it would be appreciated. its on a 68 with a dual circut master cylinder. thanks
kokodabobo- Dub Nut
- Number of posts : 303
Re: Brake pedal won't come up
id prob start replacing soft lines
zabo- Dub God
- Number of posts : 2260
may be a sticking wheel cylinder. my pedal used to not return properly, never did sort it out. i just got used to pulling it back up with my foot lol
callahan- Out of Control Dubber
- Number of posts : 1271
ill check that out tommorow. and yeah, its just too much of a pain to pull it back with my foot. i have fred flinstone feet and they just dont fit so well. have you guys ever heard or dealt with with the pedal assembly being the problem?
kokodabobo- Dub Nut
the only times ive seen the actual pedal assembly sticking they looked like they would and were covered in mud and crap
im gonna take it off and clean it up. i think that may be it. do you happen to have a roof rack you want to sell? im not too far from talking rock, and ive just been asking around
kokodabobo- Dub Nut
I've got one but I'm not itching to sell it. It's a stainless flat four rack so it's nice. Feel free to shoot me an offer
I have had the problem you have with a pedal assembles sticking. Is best to take out the rod to the master cylinder and check to see if the pedal moves free. If not then go ahead and pull out the assemble, take it apart and clean it. When you put it back together it's best to Wes whit lithium greese. It does not get stiff ini the hold weather. Good luck with it.
Cave Man- Dub Nut
- Number of posts : 333
i am with caveman the pedels probably got mud an rust an crap in tem take them apart cean an lube an it wil be like new
DOODLE BUGG- Out of Control Dubber
- Number of posts : 1643
Add a grease fitting to the base while your at it then the pedal set will last long time
type4revolution- Complete Dub Addict
- Number of posts : 907
Page 1 of 1
