oil fill removal???
oil fill removal???
Post by redneck_davis on Fri Oct 26, 2012 4:29 pm
l. Allright probaly a dumb question but i sprung a leak on my filler. Its right below the oil fill cap below the joint where the two halves meet on the filler/ breather. I assume the generator stand is cast alum and this top piece it Not? Well i bought and aftermarket Empi "oilfll ext" . It has threads on the bottom. .
Soooo how do you remove the stock beather/ fill from the alt stand itself? Sorry have no pics. Cannot find out how to post them via smart phone. ( have no computer)
1973 type one. .1600 dual port with alternator. Stock
redneck_davis
Number of posts : 188
Re: oil fill removal???
Post by bumblebuggy on Fri Oct 26, 2012 4:41 pm
There is a special tool to fit in the hole so you can unscrew it. Some people have had luck removing it with hefty needle nose pliers.
Post by ASBug on Fri Oct 26, 2012 4:45 pm
I have one of those tools and they are horrible.
All they will do is ream off the grove so that you will have to cut it off (like I did).
I imagine that an air hammer set to low would break it loose, but I used an extension and a breaker bar and mangled the grove.
Just be careful, I am not the heaviest built in the arms and I destroyed the lock down ring pretty easily.
Post by fluxcap on Fri Oct 26, 2012 4:58 pm
There are two tools for this
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-7110 (I think KC is talking about this one)
I have this one and it works great!
http://www2.cip1.com/ProductDetails.asp?ProductCode=C13%2D5102
Post by redneck_davis on Fri Oct 26, 2012 5:39 pm
Its got a hole in it so im not worried about destroying it. . But i cant afford to mess up my original alum stand. So its standard righthand threads? Big pair of channel locks and a cheater bar?
redneck_davis
Post by ASBug on Fri Oct 26, 2012 8:05 pm
Well I'll be.
That camed remover is the bee's knees.
I do have the 1st one and it is a piece.
If it is already holed, then just cut off the oil filler box and clamp on a big pair of vice grips and push hard and it'll come right out.
This is what I did to my '63's 1600 block.
Post by redneck_davis on Fri Oct 26, 2012 10:12 pm
Anyone have a good picture? Im not with my car . I won't be off work till 6. And i got two morebugs to buy and pick up after lunch when i wake
redneck_davis
