Type 1 Heater Boxes
Type 1 Heater Boxes
Post by rpm750 on Tue Aug 14, 2012 9:13 pm
Ok I've got all Type 1 stuff for Moto including heater boxes. But the lever is not in the right spot to connect to the cables. What have folks done in the past to make this work. I took a box apart tonight to look and see if I could just rearrange the arm but shaft is welded to the flapper arm inside.
Re: Type 1 Heater Boxes
Post by sploval53 on Tue Aug 14, 2012 11:23 pm
ill have to look and see how i ran mine on my doublecab i think i still have the boxes in the garage
Post by bumblebuggy on Thu Aug 16, 2012 3:23 pm
Wire it open in the winter, cut the wire in the summer. Wink
Post by peregrine67 on Thu Aug 16, 2012 6:55 pm
bumblebuggy wrote:Wire it open in the winter, cut the wire in the summer. Wink
I was hoping I wasn't the only one who does that.
Post by bumblebuggy on Thu Aug 16, 2012 7:42 pm
rpm750 wrote:Ok I've got all Type 1 stuff for Moto including heater boxes. But the lever is not in the right spot to connect to the cables. What have folks done in the past to make this work. I took a box apart tonight to look and see if I could just rearrange the arm but shaft is welded to the flapper arm inside.
Have a few boxes in the garage if ya want to come over and look at 'em.
Post by bumblebuggy on Thu Aug 16, 2012 7:43 pm
Warbird doesn't have the heater levers or cables...yet.
Post by ASBug on Thu Aug 16, 2012 8:40 pm
Irma doesn't have any heat installed...
I mean nada, nothing, zip, zilch...
Shroud doesn't even have blower ports, no heater boxes ( I have 2 good sets) and no cables.
Gonna have to cure that soon.
Post by rpm750 on Fri Aug 17, 2012 6:52 am
bumblebuggy wrote: Have a few boxes in the garage if ya want to come over and look at 'em.
Bus Boxes or just Boxes? I don't want to wire it open, would like for it to work properly.
Post by DiggerD on Fri Aug 17, 2012 9:14 am
X2
Post by bumblebuggy on Fri Aug 17, 2012 3:50 pm
I honestly don't know.
Post by shaky on Sun Aug 19, 2012 12:16 pm
I am currently using the wire it open method Bob. Have new cables that I need to install but that will require I don't know what? Pulled one old cable out of snake bus and it was a Bit$h. Do you have operating cable's?
Post by rpm750 on Sun Aug 19, 2012 12:30 pm
Yes, I have working cables. You would have to fish the new cable(s) through the tube running to the back and then up to the dash behind all the vents in the front. Should be an easy task I would think.
Post by Bugman114 on Sat Sep 22, 2012 10:55 pm
I've got 4 small electric heaters, and a universal gasket on the hood that actually SEALS the hood, XD. Instant heat, and it'll run you out of the car if you don't crack the windows after a while
Post by type4revolution on Sat Sep 22, 2012 11:39 pm
If you have the incorrect boxes then use the oldfashion metal coat hanger trick. Use a barrel nut and coat hanger at heater box end then put a barrel nut on cable end and tightend. Cut to lenght coat hanger just past the cable and barrel nut. Then loop coat hanger neatly around bolt of barrel nut. Then test heater cable it should pull open heater box and wala heat. otherwise start looking for some better boxes for propane heater
