should i...
should i...
Post by buggin70 on Sat Aug 04, 2012 11:59 am
try to replace the frame head on the pan thats on the car that has good pans
or put new pan halves on another pan i have and just swap the body?
Re: should i...
Post by sploval53 on Sat Aug 04, 2012 12:43 pm
Doing a pan head is going to be harder than doing another pan
Re: should i...
Post by DOODLE BUGG on Sat Aug 04, 2012 5:56 pm
do the frame hear an go ahead an shorten it
Re: should i...
Post by alcpsy on Sat Aug 04, 2012 9:47 pm
Just shortened mine 1 1/2 straight but putting a set of shims in bottom for caster. Wasn't hard @ all. Went ahead and sleeved the inside before mating, then strapped exterior. May be over kill but wanted to make sure it is safe.
alcpsy
Number of posts : 38
Registration date : 2011-01-09
Re: should i...
Post by rpm750 on Sun Aug 05, 2012 9:01 am
alcpsy wrote:Went ahead and sleeved the inside before mating, then strapped exterior. May be over kill but wanted to make sure it is safe.
Nothin wrong with that, no way I would ride in something that has a crap load of rust or pieced together, my but is sitting on it to boot!! Just say'n.
I understand why it's done would like to see the steps and where you cut it.
Re: should i...
Post by buggin70 on Sun Aug 05, 2012 5:26 pm
well i got too looking at the pan yesterday and there is a huge hole in the tunnel that someone cut out to replace the clutch cable so i have a useless pan... so i guess im gunna buy pan halfs now
Re: should i...
Post by buggin70 on Mon Aug 06, 2012 9:15 pm
theres 2 pictures i have for right now
Re: should i...
