Air Intake tube freezing?
Post by daltondragger73 on Fri Jan 02, 2009 6:25 pm
Ok today i took a quick cruise in my bug and 1st gear is running kinda ruff halfway thru spittin and studderin but if i put it to the floor it goes great, i got to the store and opened up the deck lid and noticed that half of my carb. and the intake manifold under the carb was white with ice like real cold to the touch i mean this was within 1 mile from my house, I made a call and a buddy said that his did that and his block ended up freezin??? he had to drop 1700. buck to get it rebuilt, so I made another call and the guy told me I need a preheat hose??? never heard of this, suposivly it goes from the intake to the carb to prevent this "freezing"..
Does any body know what the problem could be, or is this just normal, still cant figure why it runs ruff in 1st gear, the points and every thing are good??? maybe i got some water in there some how??? i dunno, any help is appreciated. THANKS!!!
and any pics of where the "preheat hose goes" would be greatful
daltondragger73
Number of posts : 334
Re: Air Intake tube freezing?
Post by Johnny on Fri Jan 02, 2009 6:48 pm
Dave...I don't have any pics-but what they're talking about is a pre-heat tube....
Where your intake comes down from your carb and then goes into the heads...there should be a smaller tube coming from the intake that would bolt onto a flange of your exhaust....it uses the heat from the exhaust to prevent the intake from freezing up.....
If I'm right....BUT...I have been wrong before.....
Johnny
Number of posts : 310
Post by Attorney Isaiah Loophole on Fri Jan 02, 2009 6:48 pm
You are experiencing icing. To fix the problem you need to clean the heat risers if they are connected to your exhaust and run a preheater hose. I will look for pics.
Post by Johnny on Fri Jan 02, 2009 6:50 pm
OK.....I was close
Johnny
Post by Attorney Isaiah Loophole on Fri Jan 02, 2009 6:54 pm
Your right Johnny
Post by Attorney Isaiah Loophole on Fri Jan 02, 2009 6:59 pm
He is some suggestions on how to clean it http://www.thesamba.com/vw/forum/viewtopic.php?t=67496&highlight=heat+riser+clean
view from under engine, left side
If you don't have a pick up pipe, put the end of the pre-heat tube on top of the lower tin, so it will draw the hot air that has been warmed by the cylinders/head.
There should be a rubber grommet in the rear tin where the 1" hose goes through, it is missing.
view from below, left side of engine.
The 1" pre-heat hose attached to the shorter version of the pick-up pipe.
the tin between the pulley and engine is mismatched, btw.
This is the later style pre-heat hose
Post by daltondragger73 on Fri Jan 02, 2009 11:17 pm
Ok thats what i was looking for THANKS guys, only thing is i dot have the stock airfilter and not stock exhaust, so the heat tube prob. wont work but i guess im gonna have to take it apart and clean the heat risers and see if that does the trick, and with the link i saw they use a clutch cable on a drill to clean it, guess ill need to find one of those too! fun fun!! maybe because im getting on the road soon ill just park it for now, ive spent enough $$ on it this tour at home to last a while.. I got a bamboo rack today!!! hehehe $25.00 couldnt pass it up, oh well something to do next time. Thanks again!!!!
daltondragger73
Post by billieco on Sat Jan 03, 2009 12:23 am
Sometimes the clutch cable trick does not work. I have had to cut the tubes in order to get them clean, then weld them back up.
Good luck.
billieco
Number of posts : 305
View user profile http://stockornaut.com
Post by 59suicide on Sat Jan 03, 2009 10:34 am
don't mean to hijack, but just wondering if dual carbs eliminate icing because the fuel dosen't have to travel as far to the cylinders
59suicide
Number of posts : 552
Post by Attorney Isaiah Loophole on Sat Jan 03, 2009 10:43 am
59suicide wrote:don't mean to hijack, but just wondering if dual carbs eliminate icing because the fuel dosen't have to travel as far to the cylinders
Correct!
Post by dbcox on Sat Jan 03, 2009 1:23 pm
My Kadrons were bad about icing up. I had them freeze almost closed one morning trying to get to work. It had just snowed and was cold. But they iced easy anyway. My webers have never frozen
dbcox
Number of posts : 70
View user profile http://www.lubedealer.com/dbcox
Post by vwovalchild on Sat Jan 03, 2009 1:54 pm
Heating the pre heat risers with a torch and then cooling them quickly with water will cause the carbon to crack and make it easier to get out or just fall out. I have done this amnt times with sucess. Try this if you get the time.
Post by daltondragger73 on Mon Feb 23, 2009 9:23 am
votwing wrote:Heating the pre heat risers with a torch and then cooling them quickly with water will cause the carbon to crack and make it easier to get out or just fall out. I have done this amnt times with sucess. Try this if you get the time.
Heat did work a bit we also banged on it with a hammer and alot of stuff came out.. but what I did try and it worked real good was went to Wal Mart and got a 6 dolla bottle of Mineral Spirits set the tube proped up side down pored the M.S. down in the risers let it sit over night then dumped it all out when it dried knocked it with a hammer a couple times and WALLA!!! it was so clean cheers so its back on and runnin good!! also the thing is like twice as loud as b4.. so bug-a-paluza loudest engine here i come!!!
daltondragger73
