68 Westy "Mobile Home"
Page 2 of 6 Previous  1, 2, 3, 4, 5, 6  Next
Re: 68 Westy "Mobile Home"
Post by Knumb Knucks on Wed Apr 04, 2012 9:00 pm
It's goin down,just gota get beam and plate installed. No off roading for me I like clean and hate cleaning dirt n mud after a weekend of off roading. Me like shiney tires sunny
Post by Knumb Knucks on Sun Apr 15, 2012 6:01 pm
Post by Knumb Knucks on Sun Apr 15, 2012 6:02 pm
Electrical Madness,. Razz
Post by ASBug on Sun Apr 15, 2012 7:13 pm
Looks nice, ya camping in it at BAP?
Post by Knumb Knucks on Sun Apr 15, 2012 9:14 pm
Yes it will be Geting used at BAP.... A Mobile Den .
Post by rpm750 on Sun Apr 15, 2012 9:46 pm
Specs on the low down settings. Please
Looks perfect!
Post by bakertim2 on Sun Apr 15, 2012 10:39 pm
We did the drill dimple and twist then reweld on the front beam (temporary) and one notch and 3" drop plates in the rear with c-notched frame.
Post by rpm750 on Mon Apr 16, 2012 6:56 am
Cool, looks good but too low for me, DD. I need to talk to ya at BAP about this drill and weld technique.
Post by bakertim2 on Mon Apr 16, 2012 9:04 am
We learned about it from Kip.
Post by Knumb Knucks on Mon Apr 16, 2012 11:28 am
If its too low your too old,LOL. Still has clearance under there.
Post by shaky on Mon Apr 16, 2012 11:39 am
Looks good.
Post by rpm750 on Mon Apr 16, 2012 8:29 pm
Kale it's a perfect height but I get tired of worrying and dodging shit in the mornings with very little light and not much ground clearance.
Post by bakertim2 on Mon Apr 16, 2012 8:50 pm
Maybe you should bag it.
Post by zabo on Mon Apr 16, 2012 9:04 pm
bob needs something that can make it over a deer.
Post by DiggerD on Mon Apr 16, 2012 10:04 pm
zabo wrote:bob needs something that can make it over a deer.
Razz
Post by rpm750 on Mon Apr 16, 2012 10:09 pm
Hit the Deer 2 yrs ago on the 14th, you don't think I'm not looking out for shit in the road! LOL too funny Zabo. It would be nice to just drive and not think about whats in the way.
On another note.....
Kale did you get your brake lights worked out? I just went and sprayed the hell out of the turn signal switch with WD and now my rear blinkers and brake lights are working. I'll bring home some electrical cleaner tomorrow and clean out the Water Displacement Formula 40!
Post by Knumb Knucks on Mon Apr 16, 2012 10:36 pm
Who drives cars big enough to hover deers scratch Mad Max your ride for animal proofing.
Post by Knumb Knucks on Mon Apr 16, 2012 10:40 pm
It was the turn signal switch,it needs replacing. Just got to hold switch a certain way and all of it works. I may try some pb on it. P.B. is useful for electrical contacts.
Post by fluxcap on Tue Apr 17, 2012 6:44 am
good to know! If I'm making a left, I have to pull the switch very slowly and hold it in the sweet spot. If I don't, the front signal flashes fast a crap and the rear does nothing. I'll have to hit it with some PB.
Post by Woneal on Wed Apr 25, 2012 9:16 pm
Looks good lowered
Woneal
Number of posts : 42
Registration date : 2012-03-27
Post by Knumb Knucks on Sun May 13, 2012 5:36 pm
Post by pwmcguire on Sun May 13, 2012 5:50 pm
fluxcap wrote:good to know! If I'm making a left, I have to pull the switch very slowly and hold it in the sweet spot. If I don't, the front signal flashes fast a crap and the rear does nothing. I'll have to hit it with some PB.
I had to hold my wiper switch in the sweet spot to get it to work. I took it apart and put some solder on the contacts to build them up. I have not had a problem with them. They worked for 2 hours coming back from Helen today. I might be a temporary cheap fix for you as well. The westy is looking good.
Post by pwmcguire on Sun May 13, 2012 5:54 pm
rpm750 wrote:Kale it's a perfect height but I get tired of worrying and dodging shit in the mornings with very little light and not much ground clearance.
I ran over a vacume cleaner in kennesaw one night, the guy beside me hit it and sent it skidding accross in front of me, it still scraped in my baja.
Post by Knumb Knucks on Sun May 13, 2012 6:19 pm
P.B. spray fixed my problem,has worked perfect since I sprayed all the components.
Post by Knumb Knucks on Sat Jul 28, 2012 8:15 pm
Snaped some shots of the bus with some camera magic today.
