Locked up engine
Locked up engine
Post by laith on Mon Mar 05, 2012 11:58 am
I am in the middle of tearing down my engine and looking for advice. I pulled the heads last night, but having issues getting the pstons and cylinders off because the pistons are stuck.
Anyone have any tricks that might help?
laith
Number of posts : 298
Re: Locked up engine
Post by Hobug on Mon Mar 05, 2012 12:17 pm
laith wrote:I am in the middle of tearing down my engine and looking for advice. I pulled the heads last night, but having issues getting the pstons and cylinders off because the pistons are stuck.
A BFH! Cool
Number of posts : 1299
Post by sploval53 on Mon Mar 05, 2012 12:33 pm
Pb blaster and a big rubber mallet or soft dead blow. And a block of wood
Post by laith on Mon Mar 05, 2012 12:34 pm
Thanks...should I be hitting the pistons or the cylinders?
laith
Post by ASBug on Mon Mar 05, 2012 12:57 pm
Pistons!
Cylinders will break fins or worse.
A good penetrant I use is equal parts acetone and automatic trans fluid.
Saw this mixture at the tractor repair place, asked about it and this is what they use to break 30 year old lug nuts loose that are caked over with rust.
Try it, you'll be surprised. It doesn't stay on the threads like WD-40 or PB blaster, so you;ll still need to oil up stuff when you get it apart.
But for penetrating and breaking loose, cannot be beat.
I just used this to break loose a 1600 that was rusted pretty bad in the cyl.
It was so locked up that I broke loose both the gland nut and the crank bolt trying to move it before I used this stuff.
I'm a belever.
Post by laith on Mon Mar 05, 2012 1:00 pm
Thanks...will try this tonight!
laith
Post by ASBug on Mon Mar 05, 2012 1:02 pm
I fixed my earlier response and added a testimonial.
Make sure to tap only Piston.
USE the concoction, it really works
Post by laith on Wed Mar 07, 2012 7:45 am
Tipped the engine on its side last night and filled two cylinders with the ATF/acetone mix. Cylinders were still full this morning.
laith
Post by ASBug on Wed Mar 07, 2012 3:28 pm
laith wrote:Tipped the engine on its side last night and filled two cylinders with the ATF/acetone mix. Cylinders were still full this morning.
You have good rings!
LOL Very Happy
Post by laith on Wed Mar 07, 2012 3:43 pm
LOL Very Happy
LOL....either that or the pistons are rusted solid to the cylinders.
laith
Post by laith on Tue Mar 13, 2012 5:32 pm
Ok. I have beat on the pistons with a 4 lb hammer and wooden drift to no avail. Wondering if I should waste any more time on this or just throw it on the scrap heap.
laith
Post by pwmcguire on Tue Mar 13, 2012 9:59 pm
laith wrote:Ok. I have beat on the pistons with a 4 lb hammer and wooden drift to no avail. Wondering if I should waste any more time on this or just throw it on the scrap heap.
Try a little heat on it, Heat the cylinder up with a propane torch, or a heat gun, then hit it.
Number of posts : 786
