74 beetle idle problems
Post by VEEDUBYAH on Sun Jan 29, 2012 5:13 pm
has been sitting a while I cant get it to idle right any ideas ? cleaned out gas tank & new fuel lines took carb apart cleaned it where should i start with the volum screw and the bypass screw?
VEEDUBYAH
Number of posts : 5
Registration date : 2011-08-21
View user profile http://www.susanmcdowell.igniteinc.biz
Re: 74 beetle idle problems
Post by Clyde on Sun Jan 29, 2012 8:51 pm
Your idle jet is probably plugged. Remove it with an 8mm wrench and clean out the hole with a wood toothpick, or blow it with a rubber tipped airgun.
Volume and bypass screws ought to be where they were before you took it apart. Always count the turns off bottom, before removal.
Post by VEEDUBYAH on Tue Jan 31, 2012 3:47 am
Thanks
VEEDUBYAH
Number of posts : 5
Post by VEEDUBYAH on Tue Jan 31, 2012 6:41 pm
its called the air correction jet its like the only one i did not take out looks all crudded up just like the idle jet on my motorcycles dummy me thats what happens when i get in a hurry now i will clean it all again saturday. thanks again
VEEDUBYAH
Number of posts : 5
