Rear tire size question on beetle
Post by fifty9singlecab on Fri Jan 20, 2012 12:04 am
Is anyone running a 195/50/15 on the rear. Mine is clicked 2 times and I have a really nice set of this size. Just wondering if these will work.
fifty9singlecab
Number of posts : 75
Registration date : 2011-09-16
Re: Rear tire size question on beetle
Post by fluxcap on Fri Jan 20, 2012 5:50 am
It'd be a much shorter tire than stock 165/15. Running it on the back will increase your RPMs a good bit. It's also fatter, not sure how much clearance you have on the backside of your tire, but if it's already tight, it could cause rubbing issues. I have short axles and stock tires. I'm down 1 click in the rear and am pretty close to rubbing.
You can go here and compare tire sizes to see the size difference.
http://www.miata.net/garage/tirecalc.html
Post by ASBug on Fri Jan 20, 2012 6:56 am
On a stock width wheel or up to a 5.5 the 195 50's look like ballons.
I ran that set up on sone 5.5 empi 8's and they just looked bad.
I still have 2 good ones in storage that I may use on a wide wheel one day.
Post by Grifspop on Fri Jan 20, 2012 7:27 am
fluxcap wrote:It'd be a much shorter tire than stock 165/15. Running it on the back will increase your RPMs a good bit. It's also fatter, not sure how much clearance you have on the backside of your tire, but if it's already tight, it could cause rubbing issues. I have short axles and stock tires. I'm down 1 click in the rear and am pretty close to rubbing.
Like Eric said, when your speedometer is reading 60 MPH, you're only going 53.6 MPH, a 10.7% error. Imagine how fast your engine is revving at 70 MPH!
Post by fifty9singlecab on Sat Jan 21, 2012 3:00 am
Ok thanks guys, I want to go a little lower in profile so what do I need. I just want the stance a little lower without clicking it again. I'm running 165/80's now...
fifty9singlecab
Post by Muffler Bearing on Sat Jan 21, 2012 7:38 am
I ran a 195 65 15. Before I swapped wheels. They were shorter than the 165s but did ballon some. There are pics of my car in the 60s section showing the tires. Try looking here also. http://www.thesamba.com/vw/forum/viewtopic.php?t=247735&highlight=wheel+tire+combo
it's what helped me a bit. But people also used some funky sizes you can only get online. I would rather deal with a person face to face when it comes to getting tires.
Post by rpm750 on Sat Jan 21, 2012 8:53 am
RPM will depend on the trans/tire combo....
Early Trans through '66 has a 4.375 R/P All Swings short hub, short axle.
Early Late Trans '67 - '73 has a 4.125 R/P. '67 - '68 Swing Axle, long Hub long Axle, '69 - '73 are all IRS, Side plates both sides.
Late Trans '74 on has a really nice 3.88 R/P. All IRS, only one side plate only.
The same tire on each of these trans R/P setups will output a different RPM at the same speed.
I'm running a 205/65r15 on the back of Geek and @ 70mph I'm turning right at 3800. I have a Tach, it might be a little low. The trans in Geek is a 4.375 R/P. I downloaded a trans calculator from a site. You can plug in different scenarios to see what the end result will be bases on different combos.
I ran the same tire on O'Bugga, that car had a 4.125 R/P and @ 70mph it turned 32-3300. Read from the same Tach.
I have a Super with the 3.88 R/P and I love it on the Interstate, not sure about the RPMs, no Tach. I'm planning on building an IRS pan to o back under Geek!
I believe that a 195/70r15 would be equivalent to the 205/65r15 diameter wise.
195 = Tread Width in mm / 70 = Side Wall Profile in % of Tread Width R = Diameter of Wheel
Post by callahan on Sat Jan 21, 2012 9:39 am
Get a 185/65 or 185/60 I run the latter. I know they will rub the inside at two clicks with stock wheels idk if they will or not with your wheel set up
Post by fifty9singlecab on Mon Jan 23, 2012 1:03 am
I'm gonna have to do something... I can drive it now and as I'm going down the road wet is way worse but it will dart from the rear as if a cop is behind me trying to pit me. It's parked in the driveway with its tail tucked between its legs scared to death right now. Can I purchase extended & notched spring plates for my 65 anywhere and send my old ones back when I change them out? If I take my car to my friend it's gonna have to sit in his garage in the way until the plates are mailed off to get done and sent back. I believe plates and a wider shorter tire should fix me up...
fifty9singlecab
