Rear Hatch Glass
Rear Hatch Glass
Post by rpm750 on Wed Jan 18, 2012 9:00 pm
I'm not wanting to hook up and use the rear window defogger, so is there a way to remove the heat traces or what split rear window will fit an early Bay rear hatch?
Re: Rear Hatch Glass
Post by sploval53 on Wed Jan 18, 2012 9:24 pm
You can't just get one cut. ??
Post by vwtattooed on Wed Jan 18, 2012 9:53 pm
Have you tried scraping with a razor blade? usually takes em off when you strip tint!!
Post by rpm750 on Thu Jan 19, 2012 6:40 am
No and No. It was late last night and I just got to thinking about it. I did walk out to the shop and look and yes it is not between the glass sections it is on the surface so I will try a mechanical method to remove it. I'm sure it's toast so why have it on there.
Post by bumblebuggy on Thu Jan 19, 2012 8:44 am
I think the hatch is interchangeable with a 66-67 so the glass may be as well.
Post by DiggerD on Thu Jan 19, 2012 8:53 pm
bumblebuggy wrote:I think the hatch is interchangeable with a 66-67 so the glass may be as well.
That's what I was thinking too..... scratch
I'm pretty sure the glass size didn't change.
