Rubber boot (bellows) at front end of transmission?
Post by Tybomb on Wed Jan 11, 2012 5:19 pm
I just removed the gear shift and rods from under my 71 Bus (Max). After looking thru various sites I ordered boots (bellows) and bushings from Bus Depot, good prices compared to a cast of thousands out there.
Question: I took the bellows, "what remained of it", off the front of the trans and it did not look like the boots (2) for the shift rod. Bus Depot said I could use the same boot to cover the area between the coupler and trans.
Anyone had this problem before? Will this work? Can't find a bellows for that location.
Thanx
Be safe.
Tybomb
Number of posts : 41
Registration date : 2010-01-13
View user profile http://www.petessinkhers.com
Re: Rubber boot (bellows) at front end of transmission?
Post by Tybomb on Fri Jan 13, 2012 7:33 am
The Germans at VW Factory are very smart, I found the remains of the boot I spoke about and found a product number on the leading edge of the rubber #211711183A. It apparently is the same or similar to 183B, the shifter boots.
Tybomb
