Bay Holes o______o
Bay Holes o______o
Post by 71_georgia_beetle on Mon Dec 01, 2008 12:40 am
I have seen them on early/mid to mid bays but don't know what they are for, so..................what are the holes for seen below?
Re: Bay Holes o______o
Post by zabo on Mon Dec 01, 2008 7:41 am
for the factory to apply some wax sealant rust protective stuff to the frame
they originally had clear plugs covering them
Post by 71_georgia_beetle on Mon Dec 01, 2008 11:04 am
zabo wrote:for the factory to apply some wax sealant rust protective stuff to the frame
Yep, here is another explanation I got from another site.
Thanks Zabo
penth2o wrote:All busses had them at one point before PO work was done on them.
They are process drain holes to allow excess primer/paint to drain out after the complete vehicle body had been dipped at the VW factory. The holes are normally sealed afterwards with a translucent colourless plastic plug which should be replaced if missing to prevent ingress of dirt and moisture. You should also find some on the inside of the rear-wheel outboard arches (i.e. wings or fenders).
The best way I could find a use for them was to use them when I undercoated the beast. They are perfect for accessing the frame rails to get undercoat in them. Another use I found was for the wiring I ran for reverse backup lights. (use hard plastic wire cover & rubber grommet). Either way they should be plugged to prevent the forementioned above. Nice find 71_geogia_beetle.
