Looking for a machine shop to redrill lug pattern
Post by Attorney Isaiah Loophole on Mon Nov 17, 2008 6:31 pm
Looking for a machine shop somewhere around griffin that can re-drill my drums to a Chevy pattern or if anyone has some 68 and later drums that are already a chevy pattern
I am wanting the drums drilled and tapped if I get them done, not really interested in getting studs as my wheel will not squeeze in without taking the axle loose
Re: Looking for a machine shop to redrill lug pattern
Post by Cambur on Mon Nov 17, 2008 8:26 pm
you are still welcome to those adapters if you want them....btw
Post by Attorney Isaiah Loophole on Mon Nov 17, 2008 8:31 pm
Yeah the front will be needing adapters. The back I am not sure yet. I need to get my hand on an adapter and see. I am thinking that if i run adapters in the rear then to take off and put on the rim I will have to unbolt the axle and lower it so i can get the tire off. Kind of a pain.... I will let you know when I get one adapter from around here and try it out
Last edited by Attorney Isaiah Loophole on Mon Nov 17, 2008 10:47 pm; edited 1 time in total
Post by Cambur on Mon Nov 17, 2008 10:46 pm
Okay, sounds good!
Post by Clyde on Fri Nov 21, 2008 9:53 pm
Most shops will need to see the drums and a wheel and a lugnut to quote your labor cost. Plan on approximately $55.00 per hour.
Post by camch on Sat Nov 22, 2008 9:36 am
davis machine shop out on chappel mill rd did ours a couple years ago
Post by vwovalchild on Wed Nov 26, 2008 12:22 am
I found it was cheaper to just buy new drums already drilled with the pattern I wanted (Porsche 5x130)
Post by vwfanatic67 on Mon Dec 01, 2008 8:10 pm
Not sure what tire size you are running but if you straight axle a bus I dont think you can get out of taking the axle loose. Just food for thought.
vwfanatic67
Number of posts : 92
Registration date : 2008-10-04
Post by Attorney Isaiah Loophole on Mon Dec 01, 2008 8:55 pm
Got 15x7 inch rims on it and I don't have to take the axles loose to get them on and off. It takes a minute but they go on and come off.
Post by vwfanatic67 on Tue Dec 02, 2008 7:00 am
That's cool. what tire size are you running? how did you lower the rear; offset spring plates or straight axle kit?
vwfanatic67
Post by Attorney Isaiah Loophole on Tue Dec 02, 2008 9:02 am
Offset springplates, 68 tranny, wheels are 15X7 with 195/50 up front and 205/60 in the rear.
Post by daltondragger73 on Tue Dec 02, 2008 2:18 pm
Attorney Isaiah Loophole wrote:Yeah the front will be needing adapters. The back I am not sure yet. I need to get my hand on an adapter and see. I am thinking that if i run adapters in the rear then to take off and put on the rim I will have to unbolt the axle and lower it so i can get the tire off. Kind of a pain.... I will let you know when I get one adapter from around here and try it out
Bryce just put airbags on the bus and the adapters u wont have to worry about all the work to get the rim off just push a button and theres your clearence... hahaha
daltondragger73
Number of posts : 334
Post by vwfanatic67 on Wed Dec 03, 2008 7:40 am
Thats wild. You must have put the springplates in at stock position and just let the bus be lowered as much as the reduction boxes lower it. My bus has the same set up with a type 3 tranny and I am running 195 60 and there is no way you can get the wheel off with out removing the axle.
vwfanatic67
Post by Attorney Isaiah Loophole on Wed Dec 03, 2008 11:49 am
One click also. Doesn't look that low but it is one click as I lowered the bus one click with the reduction boxes and just put the offset spring plates in the same location.
Post by vwfanatic67 on Wed Dec 03, 2008 12:01 pm
youve seen my bus is it as low as mine. is it tucking one or more lugs.
vwfanatic67
Post by Attorney Isaiah Loophole on Wed Dec 03, 2008 12:06 pm
No it is no that low. It is still inches from yours.
Post by Attorney Isaiah Loophole on Wed Dec 03, 2008 12:13 pm
Here it is on the stock wheels with the reduction gear boxes. Flipped spindles and one outer click (sorry about the hill is it sitting on)
Here it is with the stock wheels with the straight axle. Flipped spindle and one outer click but no motor is installed at this point.
Post by vwfanatic67 on Wed Dec 03, 2008 12:57 pm
I see yeah mine is tucking one lug nut in the back. I see says the blind man.
vwfanatic67
Post by Attorney Isaiah Loophole on Wed Dec 03, 2008 12:59 pm
Do you know how man clicks you are down? How is your front done? narrowed, flipped and adjusters...
Post by rpm750 on Wed Dec 03, 2008 1:01 pm
Love the stance, how long you had the Bus? I need to find my wife one, found several candidates. I need my arm and leg! Sad
Post by Attorney Isaiah Loophole on Wed Dec 03, 2008 1:03 pm
rpm750 wrote:Love the stance, how long you had the Bus? I need to find my wife one, found several candidates. I need my arm and leg! Sad
I have had for a year or two. Oh yeah it has bmw wheels on it now. If you are going to be at the sonic then it should be there fingers crossed....
Buses are still out there for fair deals just keep looking.
I really want a panel.....
Post by rpm750 on Wed Dec 03, 2008 1:10 pm
Yeah, I'll be at the Sonic, I hope to drive bugga on Sat. to Herrell's. Definatly will have it back on the road for the Sonic meet! Can't wait to see you guys. You bringing any tee's? I'd like a blue one XL.
Post by Attorney Isaiah Loophole on Wed Dec 03, 2008 1:15 pm
I havent got any extra shirts right now. All the ones I have are sold but I can put you down for one.
Post by vwfanatic67 on Wed Dec 03, 2008 3:45 pm
not sure. I took my spring plates off and sent them to Wagenswest and when I put it back together I put the bottom of the spring plate a half inch from the lower stop. I did not adjust the inner splines at all. The front is all Wagenswest. 4" beam adjusted about half way down with drop spindles. I am running 195 50's on the front.
vwfanatic67
