'67 Beetle "Judy"
Page 6 of 8 Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
Re: '67 Beetle "Judy"
Post by peregrine67 on Sat Jan 07, 2012 3:17 pm
Upon further inspection it appears to be a linkage issue. She's going into 3rd rather than 1st.
Post by peregrine67 on Sat Jan 07, 2012 3:58 pm
Okay if I loosen up the bolts on the gear shift I can get her into all the gears but as soon as I tighten 'em down I lose 1st and 2nd.
Post by fluxcap on Sat Jan 07, 2012 5:29 pm
Are you adjusting the shifter and reverse lock out plate when you loosen the bolts, or are you just loosening and re-tightening? If you are having trouble getting 1st and 2nd, loosen the two bolts and nudge the shifter to the right. Try to hold it in place (nudged over to the right) while you tighten it back up.
Post by Attorney Isaiah Loophole on Sat Jan 07, 2012 6:01 pm
Do you have a good shift rod bushing and shift coupler? If not do those first. Then I always just loosen the shifter enough that if I shift through the gears the base will move some too. Then I shift 1 through 4 and back to first and tighten both bolts down. Then crank it up and see what you get.
Post by peregrine67 on Sat Jan 07, 2012 9:27 pm
Cool. Thanks for the advice guys.
Post by peregrine67 on Tue Jan 10, 2012 6:17 pm
I guess I have another project in line.
Post by DiggerD on Tue Jan 10, 2012 10:04 pm
You gonna narrow and slam it on earlies? Twisted Evil
Post by peregrine67 on Tue Jan 10, 2012 10:22 pm
The beam that she came with is slightly bent and it's also about 2 inches higher than it should be. I just want to bring her down a little lower than stock. This beam isn't narrowed so I really don't have the wheel clearance to go much lower.
Post by tronview on Wed Jan 11, 2012 12:00 am
You should be able to drop it 1.75 inch running stock tires and not rub.
Post by Grifspop on Wed Jan 11, 2012 12:05 am
DiggerD wrote:You gonna narrow and slam it on earlies? Twisted Evil
If by "earlies" you mean '66-'67 slotted factory wheels, then yes Very Happy
Post by DiggerD on Wed Jan 11, 2012 7:38 pm
Razz
Post by peregrine67 on Sun Jan 15, 2012 1:35 pm
Had some friends over and got her reverse lights fixed, speedometer hooked up and several other small projects.
Post by DiggerD on Sun Jan 15, 2012 8:58 pm
Had a great time!!
Thanks for having us over.... Cool
Post by Grifspop on Sun Jan 15, 2012 10:04 pm
DiggerD wrote:Had a great time!!
X2!! Very Happy
Post by peregrine67 on Sun Jan 22, 2012 7:13 pm
ARggg!! Pounding my head against the wall trying to figure out these brake lights.
Post by peregrine67 on Sun Jan 29, 2012 4:13 pm
Took Judy for a visit over to the previous owner.
Post by DiggerD on Sun Jan 29, 2012 7:59 pm
Did they recognize her??
Post by peregrine67 on Sun Jan 29, 2012 8:10 pm
Thanks Digger. That means a lot.
But yeah, they still recognized her.
Post by Grifspop on Sun Jan 29, 2012 8:12 pm
Even with the pinstriping gone? Very Happy
Did you figure out the brake lights?
Post by peregrine67 on Sun Jan 29, 2012 8:17 pm
Dave's wife was upset that I'd taken off the pin striping. I convinced her that it had to come off because of the new doors and the eventual paint job.
Still no luck on the brake lights. It pretty much has to be the sockets. Everything else is good.
Post by Grifspop on Sun Jan 29, 2012 8:36 pm
peregrine67 wrote:Dave's wife was upset that I'd taken off the pin striping.
I've got a feeling that she wasn't the only one upset about it Shocked
Post by peregrine67 on Sun Jan 29, 2012 8:46 pm
Possibly. But he didn't say anything. He was actually suggesting I paint it red.
Post by Attorney Isaiah Loophole on Sun Jan 29, 2012 9:14 pm
I think its time for some current pictures..... Very Happy
Post by peregrine67 on Sun Jan 29, 2012 9:18 pm
Good call. I'll take some this week. Somewhere besides my driveway.
Post by DiggerD on Sun Jan 29, 2012 9:59 pm
I have one tail light assy you can have if you need it, just let me know...
