frustraded over wireing
Post by buggin70 on Thu May 19, 2011 5:06 pm
i just replaced the alternator and wired out the regulator like diagrams on the samba it worked perfectly yesterday and today but when i just tried to get in it the gen light doesn't work but the oil light does so i switched the bulbs and still just the oil light
idk what else to do
i really dont wanna take all of this out again
Re: frustraded over wireing
Post by fluxcap on Thu May 19, 2011 8:34 pm
Disconnect the idiot light wire on the alternator. Turn the Key to "on" and touch the end of the wire to a good ground (if you know the oil light is functioning correctly, touch the end of the alt wire to the end of the oil pressure wire). Does the alternator light come on?
If so, the light is working correctly and something ain't right with the alternator.
If not, something is wrong with the wire or the light socket in the speedo.
Post by buggin70 on Fri May 20, 2011 12:34 am
well i switched the lightbulbs from the oil light to the gen light and only the oil light worked again.
but after i got home from work about 4 hours later and i went to move my car both lights turned on
now im really confused lol
Post by drewBAKER on Fri May 20, 2011 1:01 am
its a light in a 1970 beetle. dont worry about little things like that. they usually sort themselves out.
Post by buggin70 on Fri May 20, 2011 1:06 am
the light has to be on for the alt to charge drew you should know that haha
Post by jmango on Fri May 20, 2011 12:30 pm
Do you have the carb with the cuttoff valve sticking out of the right side? When I installed my alternator on my 70, the switch wire would ground on the alternator, screwing up the electricals. It was so close, that it would only touch some times.
jmango
Number of posts : 24
Registration date : 2010-12-17
Post by buggin70 on Sat May 21, 2011 11:05 pm
well i drove it for like 8 min tonight just to see what it would do and it ran fine but the gen light faintly flashed for a second and i happened to notice it
i went into walmart to get some stuff and when i left the light would come on
so i guess when it gets hot it dosnt want to work?
has anyone experienced this?
Post by Bugman114 on Sat May 21, 2011 11:29 pm
if the light comes on (i'm guessing you mean its comming on while driving, no?) give it a hard rev (not so hard that you blow it up, but a good rev), and see if the light goes out. if so the brushes are sticking. had that happen to me, the problem just went away tho.
are you using an internally regulated alternator, or external?
Post by buggin70 on Sun May 22, 2011 11:48 am
no it turns on right when i turn on the car then if i turn the car off it wont come back on till it cools down to room temp i guess
internally
