guess what cylinder?
Post by jamrens on Wed May 11, 2011 5:06 pm
Doing my first rebuild i was planning on using my p&c and heads looks like a no go now..
jamrens
Number of posts : 99
Registration date : 2011-02-26
Re: guess what cylinder?
Post by Grifspop on Wed May 11, 2011 10:11 pm
My guess is #3
Post by jamrens on Wed May 11, 2011 10:32 pm
ding ding ding..
jamrens
Post by peregrine67 on Fri May 13, 2011 6:24 am
What is it about #3?
That's the same one I broke a rocker arm on and all the sites I read about adjusting valves said that #3 gets loose first.
Post by Hobug on Fri May 13, 2011 7:26 am
peregrine67 wrote:What is it about #3?
It's the cylinder that runs the hottest and therefore tends to have the most problems.
Number of posts : 1312
Post by Grifspop on Fri May 13, 2011 11:31 am
It's usually the first one to give up part of a valve and begin the destruction cycle (and like Hobug noted, runs the hottest)
Post by peregrine67 on Fri May 13, 2011 12:05 pm
Ok, but why does it run the hottest? Furthest from the fan? closest to the tranny? just wondering if there was a relatively easy way to fix it, different fan shroud etc.
Post by vw57drvr on Fri May 13, 2011 1:39 pm
You could always look for the elusive odd lobed distributor. It supposedly cures the #3 heat problem.
Number of posts : 900
Post by Grifspop on Fri May 13, 2011 4:32 pm
peregrine67 wrote:Ok, but why does it run the hottest? Furthest from the fan? closest to the tranny? just wondering if there was a relatively easy way to fix it, different fan shroud etc.
On a type 1, the oil cooler sticks up right by it, so when it heats up, the 3rd cylinder heats up. VW supposedly corrected that with the doghouse shroud, their best improvement to date
Post by shaky on Fri May 20, 2011 7:29 pm
aah, 71 doghouse improvement. Guess what I drive?
Post by bumblebuggy on Fri May 20, 2011 7:30 pm
shaky wrote:aah, 71 doghouse improvement. Guess what I drive?
Nissan Altima?
Post by jamrens on Fri May 20, 2011 8:20 pm
moped?
jamrens
Post by Grifspop on Fri May 20, 2011 10:06 pm
Going out on a limb here, but I'm going to say a 1971?
Post by Bugman114 on Sat May 21, 2011 11:33 pm
was that piston even from a pre 71 motor with internal oil cooler, or did it have a doghouse shroud/ offset oil cooler?
