DECK Lid Removal
DECK Lid Removal
Post by Terry 64 on Tue Apr 26, 2011 7:42 am
REmove my deck lid last night in about 5 minutes.
Place a blanket over it to keep from scratching
Remove 4 bolts while wife held it
Slid right off w/ no accidents,
I tried to remove spring first it would not buldge>
Terry 64
Number of posts : 50
Registration date : 2011-01-11
Re: DECK Lid Removal
Post by fluxcap on Tue Apr 26, 2011 8:42 am
Yep, I always use a thick blanket. I also removed the the stock hinge pins and now use quick release pins. I love them and will use them on every car I get in the future. Makes removal/install a one person job and keeps you from having to re-align everytime.
However, with the quick release pins, it really does help to remove the spring first. I guess I just got lucky with my spring. It is strong enough to keep the decklid fully opened, but not so strong that I can't install/remove it by hand with the decklid mounted. If I don't remove the spring first, the pressure from the spring will cause the hinge halfs to bind after the quick release pins are removed, then I'm stuck trying to wiggle the decklid free. But I've gotten to where I can get the spring on and off in just a few seconds now! The trick is squeezing yourself under the decklid and closing it down on you as much as possible to reduce tension on the spring.
Post by Major62 on Tue Apr 26, 2011 9:07 pm
fluxcap wrote:But I've gotten to where I can get the spring on and off in just a few seconds now! The trick is squeezing yourself under the decklid and closing it down on you as much as possible to reduce tension on the spring.
AND DONT LET GO !! affraid
Been thinking of putting pins on mine also
Major62
Number of posts : 285
Post by fluxcap on Tue Apr 26, 2011 9:40 pm
I tell you Randy, the first time I popped that spring loose with the decklid still attached I had to jump back and make sure all my fingers were still accounted for!
