WTF I need help
WTF I need help
Post by 72superbeetle on Sun Apr 24, 2011 9:57 pm
Ok so I got some wiring issues, first my turn signals stop working, so I check fuses clean contacts replace bulbs clean contacts check grounds replace battery and cables turn signals still no working try emergency flashers generator light comes on fuel guage starts working Alternator shorts out I'm stuck on side of road WTF help.
72superbeetle
Number of posts : 153
Re: WTF I need help
Post by bumblebuggy on Sun Apr 24, 2011 11:33 pm
You've got a short somewhere.
Re: WTF I need help
Post by Damn-it Don on Mon Apr 25, 2011 8:53 am
Start by removing non- essential fuses, then see if starting and engine are funcioning properly- with engine off, check and see if you get a spark (watch/listen)when disconnecting-reconnecting cables. Start replacing fuses one- by one, repaeating the checks each time.
This will help detirmine wich circuts have shorts in them. Get a wiring diagram for your model(or two/three that are close to yours) and trace the troublesome circuts. It's tedious, yes, but you will find your problem.
Re: WTF I need help
Post by 72superbeetle on Wed Apr 27, 2011 9:49 pm
so leave essential fuses in start motor turn off disconect battery looking for sparks rehook battery looking for spark add a fuse repeat is this correct.
72superbeetle
Re: WTF I need help
