My 65 Beetle Leela
Page 3 of 10 Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Re: My 65 Beetle Leela
Post by callahan on Wed Jun 15, 2011 8:53 pm
check tire rack idk if they're still doing those snow tires for like 30 each
Post by zabo on Wed Jun 15, 2011 9:42 pm
Put these 14s on I have for sale:-D i'llbe up tht way Fri night
Post by 86vwgti8v on Thu Jun 16, 2011 5:23 am
I called tire rack, they said about 60 a peice then shipping, mounting blah blah blah....
What 14s? Info please.
86vwgti8v
Number of posts : 317
Post by loves trim on Thu Jun 16, 2011 6:28 am
Call david at summit. He ordered my 155/60/15's. He's working tomorrow. Call me if you need the number.
loves trim
Number of posts : 258
Registration date : 2011-02-03
Post by fried_chicken on Thu Jun 16, 2011 8:45 am
Looking sweet
Post by peregrine67 on Thu Jun 16, 2011 11:46 am
86vwgti8v wrote:... still needs to replace the monster truck tires, and ...
lol! only on a VW site would 155s be refered to as "monster truck tires". I have 285s on my truck and they are a puney compaired to some of the other trucks at my office.
Post by Boom on Fri Jun 17, 2011 11:41 am
I bought mine thru tire rack but a buddy of mine says that any smart car dealer stocks them now
Boom
Number of posts : 58
Registration date : 2011-02-21
View user profile http://www.dlkweb.org
Post by DOODLE BUGG on Sat Jun 18, 2011 9:52 pm
i have a set of 14 wheels with a set of 195-70-14 on rear an 175-65-14 on front i will part with let me no just pm or call 404-259-3700
Post by 86vwgti8v on Sun Jun 26, 2011 9:19 am
Replaced the rear wheel brake cylinder, shoes, soft lines, E brake cables, axle seals, notched the spring plates.
Still haver to install the 145/65/15' s, the motor, gas tank etc. moar low to come!
86vwgti8v
Post by 86vwgti8v on Fri Jul 01, 2011 8:12 am
Scored this gem, media blasted then gonna paint it flat black.
Motor supposed to go in tuesday!
86vwgti8v
Post by 86vwgti8v on Mon Jul 04, 2011 6:10 pm
Replaced the running boards, did a alignment on the front wheels, and half way installed the decklid. Hopefully thr motor goes in tomorrow
86vwgti8v
Post by loves trim on Tue Jul 05, 2011 9:12 am
looking good
loves trim
Post by 86vwgti8v on Thu Jul 07, 2011 9:26 pm
86vwgti8v
Post by 86vwgti8v on Sat Jul 09, 2011 10:24 pm
for some reason I'm having a hard time installing the shifter. It looks really simple but when I bolt it down it doesnt want to shift. It will move threw 2 positions. Maybe 1st & 2nd And I have to fight it for that, but won't go side to side.
Any advice?
86vwgti8v
Post by drewBAKER on Sun Jul 10, 2011 10:16 am
how does the shift coupling look?
Post by bumblebuggy on Sun Jul 10, 2011 12:06 pm
X2 on the coupling. Also, don't bolt it all the way down and try and find the sweet spot.
Post by 86vwgti8v on Sun Jul 10, 2011 2:22 pm
Coupling looks bad.
Everytime I bolt it down all the way it wont move at all.
I was ale to force it into 1st 2nd and reverse, it want purty though.
86vwgti8v
Post by bumblebuggy on Sun Jul 10, 2011 10:13 pm
You do have the "D" plate in there right?
Post by 86vwgti8v on Mon Jul 11, 2011 3:45 am
I am assuming the D plate is the plate above the linkage bushings? Other wise I may not...
86vwgti8v
Post by bumblebuggy on Mon Jul 11, 2011 3:58 am
"D" plate fits between the shifter base and the tunnel. Should look like this...
http://www2.cip1.com/PhotoGallery.asp?ProductCode=VWC%2D211%2D711%2D149
Post by 86vwgti8v on Mon Jul 11, 2011 8:13 am
Definatly don't have one of those...
86vwgti8v
Post by fluxcap on Mon Jul 11, 2011 8:40 am
Well, with what you have found so far in your quest for a smooth shift, I'd guess you probably also have an old, worn out shift rod bushing or no bushing at all. This is the plastic sleeve that fits in the hanger (inside the tunnel, just rearward of the gear shifter). While you are working on the shift coupler and plate Glenn mentioned above, I'd go on and install a new one of these as well to ensure you get a smooth shift.
Good thread on the samba with shift rod bushing install tips.
http://www.thesamba.com/vw/forum/viewtopic.php?t=157519
Post by zabo on Mon Jul 11, 2011 8:41 am
stock shifter?
Post by 86vwgti8v on Mon Jul 11, 2011 1:52 pm
Yea man, it's a stock shifter....I'm gonna check ther local parts house today see what he has in stock...might have to order some stuff..thanks fur the info!
86vwgti8v
Post by callahan on Mon Jul 11, 2011 1:58 pm
did you try moving the shifter around on the tunnel? i had this problem when i put a stock shifter back in and it just had to move it over a bit then it went into all gears fine
